Thread: corvette brake calipers on W body?
Results 1 to 13 of 13
  1. #1 corvette brake calipers on W body?
    Akron Ohio
    Does anyone know how to do this?
  2. #2 Re: corvette brake calipers on W body?
    Portland Oregon
    AFAIK it's like the F-body caliper upgrade. I don't know what year vette calipers work for this though.
  3. #3 Re: corvette brake calipers on W body?
    GT Level Member duane9586's Avatar
    Apr 2008
    ny
    hit up drunkiethebear he did it and they look great
    180*, Overkill, K&N, MSD, GEN V, AL 104's,ZZP Shift kit,SD Headers,1.9rr's, 90#,3.2zzp,0KR, 8K HID,Was a Base Model
  4. #4 Re: corvette brake calipers on W body?
    C5 and C6 brakes work apparently.
  5. #5 Re: corvette brake calipers on W body?
    GT Level Member GeosGP's Avatar
    Fenton, MI
    Is there that much advantage over the F-body calipers though?
    2004 Grand Prix GTP Comp-G
    Stock, featuring more KR than you can shake a stick at
  6. #6 Re: corvette brake calipers on W body?
    GT Level Member VictorSmalls's Avatar
    Dec 2008
    Tyrone, PA
    No advantage. The Vette calipers are made of a lighter alloy and the Fbodys actually have slightly larger pots.
    Retired
    Turbo'd
  7. #7 Re: corvette brake calipers on W body?
    Actually the advantage is better brake feel.
    Smaller pots = less pedal travel for the same clamping force.
  8. #8 Re: corvette brake calipers on W body?
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    yep, that's why I run them
    Same install as Fbody but you use vette calipers
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  9. #9 Re: corvette brake calipers on W body?
    Portland Oregon
    keeping to the same years of vette? 98-02? And Z06 or non Z06?
  10. #10 Re: corvette brake calipers on W body?
    Pretty sure the C6 calipers are bigger and we only use the C4-C5 calipers...anyone know that the big Baer brake upgrade was just C4 calipers right? Just a nice way to have PFYC make thousands off people who used to buy em...
  11. #11 Re: corvette brake calipers on W body?
    I thought drunkie ran C6's
  12. #12 Re: corvette brake calipers on W body?
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    I put C5 calipers on my '98 GTP and love the pedal feel --- they'll stop on a dime and give you 7 cent of change. They bolt to f-body brackets without a problem. Bend the stock hoses forward a bit and you're good to go.
  13. #13 Re: corvette brake calipers on W body?
    Portland Oregon
    Do you need f-body brackets then, or can you use vette brackets if you get em?
  1. steel brake lines for f body calipers/12"
    By e6600 in forum Brakes/Suspension/Chassis
    Last Post: 04-10-2010, 07:13 PM
  2. Painting brake calipers.
    By Freebeer187 in forum Brakes/Suspension/Chassis
    Last Post: 08-26-2008, 01:34 AM
  3. Brake calipers and why you choose to paint them?
    By GR8racingfool in forum Visual/Body Modifications
    Last Post: 08-20-2008, 03:57 PM
