Thread: Water in the floorboard that NOT so permanent fix
Results 1 to 14 of 14
  1. #1 Water in the floorboard that NOT so permanent fix
    Donating Users ls6velless454's Avatar
    Nov 2009
    Portage, IN
    So I have been getting water in my passenger side floor board every since it has started raining outside recently. So I read the write up and purchased the deflector for about $4 from my local dealership, and ditched the old rubber piece. Unfortunately the car still leaks right through the blower motor. I honestly do not know how my blower motor still works because it had about a gallon of water in it. I took everything out and poured water in the cowl area to see if I could find the leak and I got nothing. Later that day I put everything back and everytime I take a left turn a small amount of water still ends up coming into the blower motor. I would assume it would be the seal. BTW I have no idea where a cabin air filter would be either SO any SUGGESTIONS would be awesome just chime in.
    There is no replacement for displacement........unless you have a supercharger or turbo
    2000 Bright Red GTP Coupe GXP axle back, GMPP sway bar, NGK TR6, 180 stat. (Uninstalled Aeroforce Interceptor, DHP PCM, FWI, Gen V on the way) and still no pulley in sight.
  2. #2 Re: Water in the floorboard that NOT so permanent fix
    HUDSON
    First thing to do is determine what kind of water it is, coolant? rain water?
    If the deflector is installed correclty, I don't know how it could leak, somthing you might want to check. I did the deflector in my car as soon as I noticed fresh clean water under my floor matt, passager side, have not had water since the install, and have driven through good rains too, so I know it works.
    As far as the cabin filter, I think the cars that had the filter have a 2 piece cowl cover for easy access, as opposed to the cars that do not have it, like my 2000 GTP with the big one piece cover.
    It won't hurt to give the install a check to make sure the deflector has not moved out of it's proper position.
    Dean
  3. #3 Re: Water in the floorboard that NOT so permanent fix
    Nov 2009
    Portage, IN
    It's rain water for sure. I am starting to believe I have a bigger problem because the car did the same the and the rubber bulb seal was still in place when I removed it. I believe after a good rain I got rain in the blower motor after taking left turns only. No idea what to do at this point but to clear silicone all around that.
  4. #4 Re: Water in the floorboard that NOT so permanent fix
    GT Level Member DBGP's Avatar
    Vancouver, BC, Canada
    lol great, i got the same problem. I took my car in to get the sounds system hooked up, and they said that i had a bunch of water underneath the floormat on the passenger side
  5. #5 Re: Water in the floorboard that NOT so permanent fix
    GT Level Member Lvgrandprix2003's Avatar
    Cincinnati
    I notice this is a common problem with the GP's I have had my 2003 SE for almost 6 months now and not had the issue. But I also park my car in the garage every night, and under an overpass in my parking lot when I am at work.
  6. #6 Re: Water in the floorboard that NOT so permanent fix
    Nov 2009
    Portage, IN
    Turns out you have to take out the rubber boot on the a/c evap. It's located on the passenger side. The boots tend to clog, mine was fine but after further investigation it was clogged inside the pipe. After I fixed it a gallon of water went all over the pavement.
  7. #7 Re: Water in the floorboard that NOT so permanent fix
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Right, there are two things to do here.
    1 - Remove cowl at bottom of windshield and RTV seal back in place after crimping channel in the weather stripping back closed.
    2 - Straight down from the alt is the L shaped tube that just presses onto a pipe extending from the firewall. Remove it and clean it out.
    No more leaks.
  8. #8 Re: Water in the floorboard that NOT so permanent fix
    GTX Level Member Biohazed's Avatar
    Philadelphia, Pennsylvania, United States
    do you havea sunroof? if so have you checked the drain?
    also hows the seal around your doors and windshield look?
    *image too tall*
    BMR F + R Strut Bars - Falken Torque V 18's - JVC S900 - Kicker C10's - Spyder Projectors, Wizaird,
  9. #9 Re: Water in the floorboard that NOT so permanent fix
    canada
    my buddy had this problem last week took it in ,was a vent line on blower was plugged, cost him 50.00 to have it blown out
  10. #10 Re: Water in the floorboard that NOT so permanent fix
    Pennsylvania
    Quote Originally Posted by Duane View Post
    Canadian hookers are expensive.
  11. #11 Re: Water in the floorboard that NOT so permanent fix
    Nov 2008
    Chicago
    LOL @ SlowNA
    Most cars didn't include a cabin air filter from the factory. You can install one. There is no noticeable drop in the amount of air coming out of the vents. When installing, you need to bend it in half to fit it in there. The filter is made to bend in half.
    97 GTP Sedan: 3" from the downpipe to the mufflers, no cat, ADR 17's, AGX/Eibach, HAI w/k&n, 6k HID's
  12. #12 Re: Water in the floorboard that NOT so permanent fix
    Quote Originally Posted by FuglyGTP View Post
    LOL @ SlowNA
    WHY DO YOU DO THIS TO ME?
  13. #13 Re: Water in the floorboard that NOT so permanent fix
    GT Level Member EJRJR91's Avatar
    Nanuet, NY
    i had this problem, i took it to the mechanic who took apart the whole dash and everything, he claims there wasnt a good seal around my windshield
  14. #14 Re: Water in the floorboard that NOT so permanent fix
    Odessa, MO
    Quote Originally Posted by EJRJR91 View Post
    They always do
  1. Water in floorboard (Take 2) - The Permanent Fix
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 09-16-2022, 02:02 PM
  2. Water in Passenger Floorboard [*]
    Last Post: 08-31-2012, 07:54 PM
  3. Permanent Water spots?
    By GXPimpin in forum Detailing Tips and Tricks
    Last Post: 10-15-2010, 06:15 PM
  4. Water on floorboard-one more time
    By Madness in forum How To Write-Ups/Tech Tips
    Last Post: 05-21-2010, 09:17 PM
  5. water in floorboard i need to fix
    By gotboost3 in forum General Tech Discussion
    Last Post: 06-01-2009, 12:13 AM
