Thread: Water in floorboard V.123.23423454.4543 *Update*
Results 1 to 2 of 2
  1. #1 Water in floorboard V.123.23423454.4543 *Update*
    GTX Level Member real diehl's Avatar
    Salina, KS
    We got about 4 inches of rain the other night, and some more last night. Saturday night, my car accumulated about 3 inches of water in the passenger side floorboard, the driver's side floor was damp as well.
    Sooo, I took out the entire interior. I removed the carpet, and I thought my problems were leaking rubber door weather stripping because of how the water looked like it dripped in by the door. With all the carpet out, I sprayed the sunroof and doors and watched where it came in. The sunroof doesn't leak at all. The problem was the window seal, on the outside. There's a gap in the very front of the window seal, about the size of a small nail head. The water comes in through that seal, and hits a speaker deflector, (inside the door), and apparently comes out of the bottom of the door panel right below the speaker.
    Has anybody had this problem? I know it's not the sunroof, and I've replaced the $3 cowl piece. From the factory, water comes in the door, and that's not a problem because there are drain holes in the door, but not all the water is making it to these drain holes.
    *EDIT*- Update
    Found where it was leaking, if anybody else has water leaking through the door panel I have a solution.
    signature removed for inappropriate content.
    -bio
  2. #2 Re: Water in floorboard V.123.23423454.4543 *Update*
    GT Level Member firstdue's Avatar
    Toledo, Ohio
    What was the solution? Had a bad rain yesterday and found my drivers side floor soaked, and found water around the speaker cover. Thanks!
    2009.1 Liquid Red G8 GT
    2001 Grand Prix GT Bright Red
  1. Water in floorboard (Take 2) - The Permanent Fix
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 09-16-2022, 02:02 PM
  2. Water in Passenger Floorboard [*]
    Last Post: 08-31-2012, 07:54 PM
  3. Water on floorboard-one more time
    By Madness in forum How To Write-Ups/Tech Tips
    Last Post: 05-21-2010, 09:17 PM
  4. water in heater blower fan or water on passanger floor
    By coolcat2010 in forum How To Write-Ups/Tech Tips
    Last Post: 03-19-2010, 04:20 PM
  5. water in floorboard i need to fix
    Last Post: 06-01-2009, 12:13 AM
