Thread: Replaced blower motor, still nothing. HELP PLEASE!!!
Page 1 of 3 123 LastLast
Results 1 to 20 of 46
  1. #1 Replaced blower motor, still nothing. HELP PLEASE!!!
    GTX Level Member nikkigpgt00's Avatar
    MI
    I recently lost any air blowing in my car, no heat, no air, no DEFROST! Ugh that has been a hard one.
    My dad helped me get the blower motor out, he bought a new one, attached it and we still get nothing. All the fuses have been checked and they are all good. He hasn't looked at the resistor yet because its harder to get to. If we replaced the motor and it still doesnt work does that mean its the resistor that is the problem? This is something that needs to get fixed asap! Driving with no defrost in the weather we have been having is not good! Any suggesstions on what to do next?
  2. #2 Re: Replaced blower motor, still nothing. HELP PLEASE!!!
    GT Level Member gpbastard's Avatar
    Florida
    Quote Originally Posted by nikkigpgt00 View Post
    generally the resistor go's out 1 or 2 speeds at a time. if you have the original factory resistor in i would go ahead and replace it anyways. there about $25.00 0r $30.00 and it's an upgraded resistor as well and it might fix your problem as well. also have you got the passenger side water leak fixed as well? all three of these items go hand in hand. water leaks on your passenger side footwell but it travels throught the blower compartment first sometimes taking the motor and resistor with it. well, i need to go as my "break" is over....
  3. #3 Re: Replaced blower motor, still nothing. HELP PLEASE!!!
    Florida
    Quote Originally Posted by gpbastard View Post
    also, do you have the automatic climate controls? if you do that could complicate matters as well as they're a more complex system...
  4. #4 Re: Replaced blower motor, still nothing. HELP PLEASE!!!
    Florida
    this is also symptomatic of a failing ignition relay as well, but i have a cheap and easy fix if it is...
  5. #5 Re: Replaced blower motor, still nothing. HELP PLEASE!!!
    Ridin' the Blue IrishNation24's Avatar
    San Diego, CA
    resistor, trust me. i had the same problem. its not 1 or two speeds a t a time. its 1-4 and then 5, i would get 5 sometimes, but more then often not. it was just not quite 100% bad. get the blower motor resistor from rockauto.com, cheapest u will find. that IS the problem.
    http://www.grandprixforums.net/membe...lbums-car.html
    2001 GTP special edition. lots of mods.
    1994 Greenwood C4 LT1-traded in for 6700 with 160K miles for....
    a 2004 LE MANS COMMEMORATIVE EDITION Z06 23K MILES.
  6. #6 Re: Replaced blower motor, still nothing. HELP PLEASE!!!
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    well the resistor is right next to the motor so it's just as easy to get to.
    if none of your speeds (1-5) are working then it's likely the resistor. if you have 5 only and 1-4 don't work, it's the ignition switch.
    i have a brand new duralast resistor if you're interested
  7. #7 Re: Replaced blower motor, still nothing. HELP PLEASE!!!
    San Diego, CA
    your back will feel nice after words too.
  8. #8 Re: Replaced blower motor, still nothing. HELP PLEASE!!!
    Florida
    Quote Originally Posted by IrishNation24 View Post
    i couldn't walk for a week after i did mine...
  9. #9 Re: Replaced blower motor, still nothing. HELP PLEASE!!!
    San Diego, CA
    dude, it was horrible. i pushed the seat all the way back, put the seat back down as far as possible, and layed upside down with my head under the glove box lol. i thought i was gonna break in half when i got out.
    that was even worse then after i spent 2 days tearing apart the engine, all bent over and ****.
  10. #10 Re: Replaced blower motor, still nothing. HELP PLEASE!!!
    Florida
    yeah, but you saved a hundred bucks or more in stealership money. my brother had his BM and resistor changed at goodyear. $400.00....
  11. #11 Re: Replaced blower motor, still nothing. HELP PLEASE!!!
    Akron Ohio
    Ha Ha I did this, me and my dad took turns working on it, its a pain lol but it fixed my problem.
  12. #12 Re: Replaced blower motor, still nothing. HELP PLEASE!!!
    San Diego, CA
    Quote Originally Posted by joshsgtp View Post
    why did it take turns? only takes maybe 20 minutes.
  13. #13 Re: Replaced blower motor, still nothing. HELP PLEASE!!!
    GTP Level Member
    springfield IL
    my blower motor stopped working also so... try'd a new one still nothing, checked the old one it works. been told its the resistor just havent got around to it.. this GP is a 2nd car i drive sometimes... got in it 2day to move it, after i started it i noticed the blower motor working..!! it was on high but i tried to turn it down it shut off and wouldnt turn back on. even tried to let the car sit (not running) for a few hours, it never came back on...
    so should i still get a resistor.........?????????????????????
  14. #14 Re: Replaced blower motor, still nothing. HELP PLEASE!!!
    Florida
    Quote Originally Posted by tc300 View Post
    more than likely you have the original resistor in there from the factory. these are prone to failure because of the materials used. there a ceramic plate with the electrical pathways etched on. if you buy a new one they are now an upgraded part so either way it's a good idea to put one in and they're only about $30.00....
  15. #15 Re: Replaced blower motor, still nothing. HELP PLEASE!!!
    Akron Ohio
    Because being upside down in the passenger seat is not fun for 20 minutes.
  16. #16 Re: Replaced blower motor, still nothing. HELP PLEASE!!!
    San Diego, CA
    we're getting off topic. i should have asked if it was MGB first. i assumed it was as not very many people custom paint their GP's...
    yeah, my bad. alot of people say that or call it baby blue, it just gets me irritated
    we all missed you Irish, we truely did.
    **** man, by seein all those pics tho, once i opened the hood, or the doors i woulda been blown away. btw, are yours the stock leather seats that u colored or are those different?
    ha.. good point.
  17. #17 Re: Replaced blower motor, still nothing. HELP PLEASE!!!
    MI
    Yea its quite a squeeze doing this work! I have had no leaking problems, one day all speeds worked and the next absolutely nothing. The resistor is getting replaced next. IF that doesnt fix it, whats this ignition relay you speak of and where is it?
  18. #18 Re: Replaced blower motor, still nothing. HELP PLEASE!!!
    Florida
    here's the link for the ignition relay mod. pretty self-expanatory:ClubGP Message Forum troubleshooting
  19. #19 Re: Replaced blower motor, still nothing. HELP PLEASE!!!
    Florida
    don't jump on the ignition mod right away as it's the last thing in your arsenal of troubleshooting/repair. double check that all your connections are tight and corrosion free. you can hook up your old motor to your battery and see if it works on that then go from there...
  20. #20 Re: Replaced blower motor, still nothing. HELP PLEASE!!!
    San Diego, CA
    verrry unlikly that its the ignition relay. mines been ****ed since i got the car, i replaced the resistor over a year ago now, and its worked perfect since then.
  1. Blower motor OR blower motor resistor
    By DDK in forum General Tech Discussion
    Last Post: 06-01-2010, 07:38 AM
  2. blower motor
    By littlenoz in forum General Tech Discussion
    Last Post: 12-30-2009, 07:10 PM
  3. Replaced Blower Motor Resistor:(
    By lambokit in forum The Rant Forum
    Last Post: 10-17-2009, 02:31 PM
  4. Blower Motor?
    By TheOtherNick in forum General Tech Discussion
    Last Post: 11-18-2008, 12:09 AM
  5. replaced new blower resistor and still no heat
    By nemesis in forum General Tech Discussion
    Last Post: 11-02-2008, 12:29 AM
