Thread: open cone
Results 1 to 13 of 13
  1. #1 open cone
    SE Level Member CompCam21's Avatar
    chicago
    So i just put an open cone at the end of my t.b. today. I have a 98 gtp just f.y.i. I realize i get no performance increase from this i just like the louder supercharger note. My question is regarding the sensor that used to be connected on the stock tubing. I am not sure what it is think i have herd it called the iat i think its probably for monitoring air intake temps but could be wrong. Anyways, right now i just have it disconnected and secured down so it isnt bouncing around. Is this going to cause any serious problems? I have not thrown any codes yet, i guess it could be pulling spark which probably wouldnt be ideal. Just could use some advice. thanxs
  2. #2 Re: open cone
    Banned - Busted For Scamming
    Feb 2009
    Nope.
  3. #3 Re: open cone
    chicago
    so just leave it disconnected and dont worry about it?
  4. #4 Re: open cone
    Feb 2009
    Leave it plugged in.
  5. #5 Re: open cone
    chicago
    i no longer have the section of tubing on that it was connected to
  6. #6 Re: open cone
    Feb 2009
    Just leave the connector plugged in to the sensor and tie it up near the cone filter.
  7. #7 Re: open cone
    leave the sensor connected to the plug like mini said and tie it up somewhere around the cone so it reads somewhat of what the cone is pulling in.
  8. #8 Re: open cone
    chicago
    k thanks appreciate the advice and quick response
  9. #9 Re: open cone
    Or if it worries you that much you can get a rubber fitting inbetween the TB and filter and drill a hole for the IAT sensor and stick it in there...its your call
  10. #10 Re: open cone
    Donating Users Ibwrong's Avatar
    Oklahoma City
    I think the key is dont leave it unplugged!
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  11. #11 Re: open cone
    chicago
    i have got it plugged back in and zip tied so that it is right next to the cone on the firewall side. I dont think i could drill a hole because i dont think their is a large enough gap between the end of the TB the cone to fit the iat so i will probably just stick with this set up since u guys said it should have no negative effects
  12. #12 Re: open cone
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    you should go buy a small extension for it and put it in! also the reason ur not noticing any performance is its sucking hot air cuz its so close to the engine so ur probably loosing performance
  13. #13 Re: open cone
    necromancers exist on the internet?
  1. open cone filter
    By GTP Ryan in forum Off Topic Discussion
    Last Post: 04-20-2010, 10:47 PM
  2. spectre open cone IAT placement.
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 04-16-2010, 07:47 PM
  3. open cone filters
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 11-16-2009, 07:30 PM
  4. Open Cone Performance.
    By PontiacGTPSE in forum Off Topic Discussion
    Last Post: 10-21-2009, 11:03 AM
  5. Cone filters
    By bat119 in forum General Tech Discussion
    Last Post: 02-27-2008, 06:00 PM
