Thread: Water in LR brake light housing/ABS light
Results 1 to 3 of 3
  1. #1 Water in LR brake light housing/ABS light
    SE Level Member andante147's Avatar
    Winfield, IL (DuPage)
    Just bought my '03 GTP. Has 124K on it, very clean and runs great. It's having the ABS and Traction control light problem, and I'm in the process of deciding what steps to take on that. The guy I bought it from had some hubs/sensors replaced not too long ago, but they might be bad again.
    Here's my question.... there was a LOT of water in the right rear taillight housing. I dumped and blew out as much as I could but it's not completely gone.
    Could this cause the ABS light (i.e. electrical issue from the water)?
    Is there a way to keep this housing dry?
    If I have to replace, all I find so far is OEM. Don't I want something improved? Where should I look for it?
    Thanks
  2. #2 Re: Water in LR brake light housing/ABS light
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    there is simply no way in hell water in the taillight could be causing the ABS light.
    you either have a bad front hub/bearing, or a bad connection between a front wheel bug/bearing and the computer it goes to. check the wiring.
    the taillight housing is a very common problem. when it happened to me i got 1 on ebay for $30 in new condition
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  3. #3 Re: Water in LR brake light housing/ABS light
    Dallas
    I am having the same issue with my 04 GP. I was told that the hub sensor went out which in turn caused the abs module to go out. I had the new hub put on and I purchased a used module put on. It corrected the problem for a a month and now I am having the same problem again. Not sure what to do at this point.
  1. metal lightbulb shield inside light housing? is it needed or not
    By Joe m in forum Audio, Security & Visual Electronics
    Last Post: 11-17-2010, 06:26 AM
  2. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  3. removing dome light housing
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 01-16-2010, 06:45 PM
  4. my 4th brake light and 3rd reverse light
    By HART in forum Visual/Body Modifications
    Last Post: 11-05-2009, 01:33 PM
