Thread: Gas Guage Not Working...Code P1441
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21 Re: Gas Guage Not Working...Code P1441
    GT Level Member AdamBall's Avatar
    Wausau, WI
    So this just started to happen to me again it did it back when I bought the car and it resolved itself now almost 2 years later it started doing it again.
    But my question is I have to drop the fuel tank to get at the Fuel Level Sensor because its attached to the fuel pump assembly correct?
  2. #22 Re: Gas Guage Not Working...Code P1441
    SE Level Member 97GTzbban1's Avatar
    Royal Oak, MI
    I have a '97 and do NOT have to drop the tank...access is through the trunk/back seat....not sure about what your car may require, maybe someone more familiar with the different years/locations can be of more help......and yes, I believe it's connected to the fuel pump assembly itself.
    1997 GT bone stock.
  3. #23 Re: Gas Guage Not Working...Code P1441
    Wausau, WI
    Alright I will have to take a look at my Chilton book a buddy has it right now just thought I would ask on here I hope its as easy as going through the trunk because I have had to drop fuel tanks before and its possibly my least favorite thing to do.
  4. #24 Re: Gas Guage Not Working...Code P1441
    Royal Oak, MI
    I haven't personally done my fuel pump yet, but going through the trunk/back seat , I've heard, is way easier than dropping a tank.....best of luck! Will you let me know how it all went when you do decide to replace it? Thanks.
    1997 GT bone stock.
  5. #25 Re: Gas Guage Not Working...Code P1441
    Wausau, WI
    yup I will let you know may be a couple weeks unless it decides to "fix" itself again haha
  6. #26 Re: Gas Guage Not Working...Code P1441
    SE Level Member jshifti33's Avatar
    South Bend, IN
    I had this exact same problem. I too thought that the sending unit was bad. Luckily, before I purchased a new sending unit I decided remove the fuel pump. When I got into it I found that fuel pump o-ring had been replaced by someone who didn't know what they were doing. The o-ring had fallen out of place and was holding the float down making my gauge read empty. After, replacing the o-ring the right way the check engine light went away and my fuel gauge worked.
    However, if your gauge is reading full all the time then it is probably the sending unit.
    You can test if it is the fuel pump o-ring like mine was by simply filling the tank. If you notice that fuel leaks out just before the gas pump clicks off you have a bad o-ring not a bad sending unit.
    If it is not your o-ring it still may not be the sending unit. On the float arm there are metal contacts that tell the computer how much gas is left in the tank. Sometimes these can get corroded. If this is the case simply clean it with a pink eraser.
    Hope this helps you.
  7. #27 Re: Gas Guage Not Working...Code P1441
    Royal Oak, MI
    Quote Originally Posted by AdamBall View Post
    Thanks....and lol. It's a GM.....enough said?
    1997 GT bone stock.
  8. #28 Re: Gas Guage Not Working...Code P1441
    Royal Oak, MI
    Quote Originally Posted by jshifti33 View Post
    Good info....mine doesn't leak...pretty sure it's the sending unit, but am not planning to replace it till the pump actually goes. If it ain't broke, don't fix it...lol...but all I do is hit the trip reset and go about 300 miles and fill up, repeat procedure....Will have a new one lined up, ready to go when that time comes. Thanks for the info!
    1997 GT bone stock.
  9. #29 Re: Gas Guage Not Working...Code P1441
    South Bend, IN
    Glad to help.
  10. #30 Re: Gas Guage Not Working...Code P1441
    Wausau, WI
    Thank for the info, to tell you exactly what mine is doing. It says its full then as your driving it will dramatically drop to empty and sit there for a bit and it may float up to either half or else it will read that it is completely full again. And this happened like 2 years ago but it resolved itself since I was to lazy to fix and since I knew how far I could go on a full tank I wasn't to concerned about running out of fuel.
  11. #31 Re: Gas Guage Not Working...Code P1441
    GT Level Member gpbastard's Avatar
    Florida
    Quote Originally Posted by 97GTzbban1 View Post
    i did mine about a month ago. $30.00 for the fuel level sensor (that's what it's called) through rockauto. on a 97 it's about $120.00 though. it takes 2 people to put the locking ring back on. also the new sensor comes with a new fuel pump gasket..
    gpbastard
  12. #32 Re: Gas Guage Not Working...Code P1441
    Wausau, WI
    Well driving my car today it died and the fuel pump fuse blew and i replaced it and it blew right away again. So now I have to really look at this problem.
  13. #33 Re: Gas Guage Not Working...Code P1441
    Royal Oak, MI
    Ouch, that sucks...good luck!
    1997 GT bone stock.
  14. #34 Re: Gas Guage Not Working...Code P1441
    Wausau, WI
    Thanks the pump came out very easy I went through the trunk it was the easiest fuel pump change I ever did but the pump cost me 230 dollars.
    My old pump the wires were melted and one of the plugs was all burnt up the thing got super hot which is not good. Thank god it didnt start a fire on me.
  15. #35 Re: Gas Guage Not Working...Code P1441
    Royal Oak, MI
    Glad to hear you got it fixed! Yea, fire and gas don't mix really well...lol. Just curious...did it take 2 people to put the locking ring back on? I'm asking 'cause I'd like to know, when I end up needing to do mine, if I should ask someone to come and help me with that......thanks.
    1997 GT bone stock.
  1. eratic gas guage
    By russells350 in forum Introductions/Noob Questions
    Last Post: 05-14-2010, 06:48 AM
  2. site working and then not working etc.
    By Rocket468 in forum Site/Club News
    Last Post: 03-24-2010, 11:53 PM
  3. 04 GTP Temp Guage Quit Working
    By trick94cobra in forum 04+ Specifics
    Last Post: 11-11-2009, 09:07 PM
  4. gas guage
    By 07gpx in forum Introductions/Noob Questions
    Last Post: 09-07-2009, 05:58 PM
