Thread: I have a couple of questions about problems I ran into...
Results 1 to 10 of 10
  1. #1 I have a couple of questions about problems I ran into...
    SE Level Member NineD9GT's Avatar
    Dec 2008
    PA
    I just finished my swap, and here are the problems I'm having.
    1- Low oil light is on when the car is on in P, N, D ,and 1. Goes off in R, OD, and 2
    2- Temp gauge is inop.
    3- Fans not working (they work off of temp gauge?)
    4- I have a white plug by battery w/ 2 wires in it (one gray and one green) My old harness didn't have this, where was it?
    5- Code P0102 Maf low voltage
    6- The harness I used from the GTP doesn't have the ABS wires where my GT harness did. *this is the least of my concerns, but I'd like to figure this out.
    7- no gear indicator light/ backup lights
    The cars were both 99s
    I know this is jumbled, but it's late here, and I've been racking my brain all weekend on this.
    Here are my pics of progress so far. I can take a pic of white plug if that helps. Any ideas? Maybe a boost in the right direction? Thanks in advance.
    Gt to gtp pictures by gotroxblazer - Photobucket
    99 GP GT L26 bottom end, Intense stage II cam, Ported L67 heads w/ LS6 springs, LS1 valve seals, 42.5# injectors, ported sc/intake, custom LS1 TB and MAF, custom FWI, 3.4 mps, NGK TR6, ZZP wires, 180 stat, etc...
  2. #2 Re: I have a couple of questions about problems I ran into...
    kind of confused as to why you even used the GTP wiring harness.
  3. #3 Re: I have a couple of questions about problems I ran into...
    Dec 2008
    PA
    what's wrong with using it? It was already on the engine.
  4. #4 Re: I have a couple of questions about problems I ran into...
    nothing is wrong, it just is a little easier to use the GT wiring harness if its already there in the engine bay.
  5. #5 Re: I have a couple of questions about problems I ran into...
    Dec 2008
    PA
    Either way, I used the gtp harness. I found a blown fuse tonight, that I must have overlooked earlier. This solved my mass air code and nothing else. I did find out that there's a resistor that plugs into that white plug by the battery. I got one, and plugged in, still no difference. Anyone know where I can find good wire diagrams?
  6. #6 Re: I have a couple of questions about problems I ran into...
    Dec 2008
    PA
    Well, I've been on alldata since I got home from work staring at pin locations in every connection on the car. I think I found the culprit. *I hope* The Black plug (C1) in the back of the engine compartment mounted fuse block. (This is where the engine harness connects to the block) I got to the bottom row of this plug and found four wires in it. Each wire is related to a problem I'm having! This might be wishful thinking, but I'm really leaning toward that plug not being in straight or something. Now I have to wait till tomorrow after work to go look at it. My car is at my buddy's garage. Oh well, I think I'm onto something.
  7. #7 Re: I have a couple of questions about problems I ran into...
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    Well???? Was that the problem? Do you have pics? I'm getting ready to swap a 05 GTP S/C 3800 into a 04 GP. Any and all suggestions would be appreciated. Thanks.
    Lambokit to be built!!!!!
  8. #8 Re: I have a couple of questions about problems I ran into...
    Dec 2008
    PA
    Sorry, what I did was swapped back in my old wire harness. It solved every problem. The donor car was hit in the left front, and had some damaged wires. I thought I had them all fixed. Guess not. I knew my old harness was good, so I swapped that in, and it works great now. After about a month of having engine in car, I spun a bearing, that's where it sits now. I have another engine to go in, but have no time at the moment. I'm also going to rebuild the trans while its out.
  9. #9 Re: I have a couple of questions about problems I ran into...
    Apr 2009
    Radford, Virginia
    I totally understand that... I have around 10 projects going at any one given time. The Kit car is just one of them. I have an 87 Mustang GT Conv. 5.0 that's another. And so on and so on and so on.... hahaha
  10. #10 Re: I have a couple of questions about problems I ran into...
    Dec 2008
    PA
    Well, when my engine went, I bought a wrecked Bonneville SSEI for the engine. Two weeks ago, I bought two more bonnevilles to fix and resell. I ended up using front end parts off of the SSEI for one that I bought. Its like a Pontiac dealer here. Haha! Now, I'm thinking about putting the engine in my GP, selling that, and my other two bonnevilles, and buying a GTO. Not sure what I'm doing. I always change my mind. Good luck with swap.
  1. couple of questions, couple of issues
    By zero in forum General Tech Discussion
    Last Post: 12-30-2009, 04:48 PM
  2. A couple of questions.
    By Enjoijoe in forum General Tech Discussion
    Last Post: 04-12-2009, 07:56 PM
  3. I have a couple of questions.
    Last Post: 03-12-2009, 07:07 PM
  4. I Have a couple questions.
    By thenervemann in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2008, 08:07 PM
  5. couple questions on my gt
    By 59chevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-04-2008, 08:58 PM
