Thread: How to remove my dash?
Results 1 to 5 of 5
nikkigpgt00 How to remove my dash? 04-24-2010, 02:35 PM
TheOtherNick Re: How to remove my dash? 04-24-2010, 06:42 PM
Wigsos Re: How to remove my dash? 05-27-2010, 01:45 AM
machinegunsquid Re: How to remove my dash? 05-27-2010, 01:47 AM
IrishNation24 Re: How to remove my dash? 05-27-2010, 08:12 PM
  1. #1 How to remove my dash?
    GTX Level Member nikkigpgt00's Avatar
    MI
    Is there a complete write up on removing the dash and the gauge cluster? I bought some gauges and need to see how hard its going to be to do the job? From what I remember removing the dash isnt too bad but what is involved in actually removing the gauge cluster to get my gauges on? Would it better to do it without removing the cluster?
  2. #2 Re: How to remove my dash?
    Charles City, IA
    2 screws in the knee pad under the wheel. Then you just pull the dash bezel off. Then you can get at the cluster, it is like 4 bolts to remove.
    SMGPFC Two Nipple General
  3. #3 Re: How to remove my dash?
    Naples
    yea, what he said, its very simple, accidentaly did it when i was installing my system
  4. #4 Re: How to remove my dash?
    Florida
    Ok, pop the dash off (you'll need to put the wheel as low as it can go)
    Then there are 2 screws at the top of the cluster that hold it to the back of the dash support.
    Unplug both connectors.
    Unscrew the 5-6 screws holding the shield on the gauge cluster.
    DONT **** WITH THE NEEDLES.
  5. #5 Re: How to remove my dash?
    Ridin' the Blue IrishNation24's Avatar
    San Diego, CA
    uhhhhh i "****ed" with the needles when i cut that stupid overlay out, u just cant take em off, u can move em around, it wont matter. if they dont go to where they should when u turn it back on they were ****ed anyway. still be carefull and dont touch em if u dont have to.
    http://www.grandprixforums.net/membe...lbums-car.html
    2001 GTP special edition. lots of mods.
    1994 Greenwood C4 LT1-traded in for 6700 with 160K miles for....
    a 2004 LE MANS COMMEMORATIVE EDITION Z06 23K MILES.
  1. How TO REMOVE OIL PAN??
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2009, 10:37 PM
  2. How to remove oil pan
    By CheeseWithMyWHINEplz in forum General Tech Discussion
    Last Post: 07-01-2009, 01:54 PM
  3. Can't remove key
    By GrandPrixlbc in forum General Tech Discussion
    Last Post: 08-08-2008, 06:30 PM
  4. How Can I Remove This ?
    By stlmo_gtp in forum Visual/Body Modifications
    Last Post: 04-23-2008, 01:18 PM
