Thread: ABS and TCS Off lights are on
Results 1 to 4 of 4
  1. #1 ABS and TCS Off lights are on
    OH
    I was cruising at highway speeds (about 80ish) and all of a sudden my ABS and my TCS Off lights went on. Not sure why. Neither of them will turn off.
    Was wondering if anyone knows why this happened and what I could do to fix it.
    My friend said it might be the wheel speed sensors.
  2. #2 Re: ABS and TCS Off lights are on
    GT Level Member GreenNirvana101's Avatar
    Feb 2008
    Wisco
    This happened to me a few weeks ago...
    I went out and unclipped and re-connected the wheel speed sensors on the front wheels. They were pretty dirty and full of wet grout.... I cleaned them up a little and reconnected them. Got back in my car and the lights turned off immediatley. Haven't had a problem sense! Make sure to check everything out before replacing the wheel hub assembly (the wheel speed sensor is attached to the entire hub assembly).
    Former Camaro muscle and DSM turbo owner - now moving into the GTP Supercharged world!
    1997 GTP - STOCK.... for now
  3. #3 Re: ABS and TCS Off lights are on
    OH
    Ok thanks, I'll have to check that out.
  4. #4 Re: ABS and TCS Off lights are on
    PA
    That is the first thing to check, from there, you will need to have the ABS code read with a proper scanner. That will tell you exactly what wheel is giving the problem. From there you can diagnose pretty easily.
    2001 GSE
  1. Just parking lights?
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 09-01-2008, 01:24 PM
  2. tail lights
    By rodman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-16-2008, 01:58 PM
  3. what cause the lights ?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-31-2008, 05:23 PM
  4. Custom Fog Lights Only
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 03-10-2008, 05:29 AM
  5. Dash lights out
    By archemedes in forum General Tech Discussion
    Last Post: 01-24-2008, 01:13 PM
