Thread: Question - Fuse blows on insertion
Results 1 to 7 of 7
  1. #1 Question - Fuse blows on insertion
    Ontario
    Hi there, I am new to this forum and I am hoping someone can give me some ideas as to how to fix this issue. I have a 2001 Grand Prix 3100 V6. I would like to use my auxillary power outlet in order to charge my phone/ipod. It uses a 15 amp mini fuse. When I go to replace the fuse, it sparks and shorts out the fuse.
    Any ideas on what to do? Any help would be appreciated.
    Thanks again.
  2. #2 Re: Question - Fuse blows on insertion
    GT Level Member hourang's Avatar
    commerce, mi
    you have a short in the system. inspect all the wires that are linked to that fuse.
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  3. #3 Re: Question - Fuse blows on insertion
    Donating Users ls6velless454's Avatar
    Nov 2009
    Portage, IN
    The wires are def. grounding out somewhere time to take apart the harness wrap and search
    There is no replacement for displacement........unless you have a supercharger or turbo
    2000 Bright Red GTP Coupe GXP axle back, GMPP sway bar, NGK TR6, 180 stat. (Uninstalled Aeroforce Interceptor, DHP PCM, FWI, Gen V on the way) and still no pulley in sight.
  4. #4 Re: Question - Fuse blows on insertion
    Nov 2009
    Grand haven
    Quote Originally Posted by ls6velless454 View Post
    THIS!!!
  5. #5 Re: Question - Fuse blows on insertion
    Willoughby, Ohio
    i would take out the plug itself and inspect that
  6. #6 Re: Question - Fuse blows on insertion
    Ontario
    Thanks! My next question is how do you remove the panel? I can remove the ashtray to search that one, but the auxillary power outlet I am not sure how to remove it. I did figure it was a short, but just wanted to ask the experts!
  7. #7 Re: Question - Fuse blows on insertion
    SE Level Member RideMr2's Avatar
    Memphis
    The dealer uses a special tool, it has little rabbit ears on it that spread out, and help pull that thing out.
    You can use a screwdriver, it you are really careful, and keep prying away at the thing, it will come out.
    Worst case, you break the little plastic clips off the end, and need a new one.
  1. Intake blows to pieces..fire erupts
    By GT Gurl in forum General Tech Discussion
    Last Post: 10-06-2010, 08:50 AM
  2. My heat only BLOWs on WINDshield?
    By nateberry in forum General Tech Discussion
    Last Post: 02-10-2010, 05:04 PM
  3. ac blows a fuse
    By brown54b in forum General Tech Discussion
    Last Post: 06-28-2009, 08:38 PM
  4. 3.8 series II sc blows smoke with rev
    By GTX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-16-2008, 01:09 PM
  5. Interior Light Fuse Blows....
    By hester21289 in forum General Tech Discussion
    Last Post: 03-12-2008, 08:02 PM
