Thread: Fuel Line O rings
Results 1 to 14 of 14
  1. #1 Fuel Line O rings
    SE Level Member 4boostin's Avatar
    Feb 2010
    Utah
    Turned my ignition on without starting the car and smelled gas. Popped the hood and saw a little gas under one of the fuel lines that go over the SC where there is some kind of union. I checked it a few more times and it hasn't leaked again, but I wanted to know...is there an O ring in there that can be replaced? Do the fuel lines pull apart at that union?
    98GS - 3" DP & Cat back, 9" K&N CIA in FW, Plog, 3.5", 180* Canned tune. 14.65 at 96.9mph, w/2.37 60ft. on G-Timer @ 4500 elev. @ 51*.
    87 Limited Turbo Regal- 12.04 @ 115 -Purchased New. Sold after 23 years and 115,000 miles
  2. #2 Re: Fuel Line O rings
    Donating Users
    South Deerfield, MA
    Yes, there are two o-rings in each one that can be replaced. You need a special fuel line tool to separate the coupling. There is a write up on here somewhere showing how it is done.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  3. #3 Re: Fuel Line O rings
    Wichita
    ^^^What? What? The O-ring can be replaced? That isn't what GM told me when they had me pay $166 for a brand new fuel line to stop my leak. But to take out the O-rings you have to take out the metal quick lock, & that thing is easily broken. So be careful or you'll be buying a new fuel line like I had to.
  4. #4 Re: Fuel Line O rings
    Joliet, IL
    why the fukk would you get a new fuel rail just go to a junkyard....
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  5. #5 Re: Fuel Line O rings
    Wichita
    A fuel line is a part I would not buy used.
  6. #6 Re: Fuel Line O rings
    ...why the hell not?
  7. #7 Re: Fuel Line O rings
    Wichita
    Could be damaged, rusted, leaky. It may seem stupid to some ppl to waste money on a new fuel line, but it just seemed smarter than buying a used one at the time.
  8. #8 Re: Fuel Line O rings
    Feb 2010
    Utah
    Quote Originally Posted by Silver GTP View Post
    Thanks!
  9. #9 Re: Fuel Line O rings
    Largo, Florida, United States
    if its engine related i always buy new.
    now it was a Seat or plastic panel i would buy used
  10. #10 Re: Fuel Line O rings
    GTP Level Member SuperSport's Avatar
    Michigan
    I did a write up for my GT. Follow the same part number and process as I did, except you need a special removal too for the lines. The o-rings are the same part number and size as the ones I changed in my GT, the connector just looks different.
    My o-rings were BAD. And part of my fuel line is burned. I think it caught fire once before I bought my car.
    http://www.grandprixforums.net/f81/c...res-30008.html
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  11. #11 Re: Fuel Line O rings
    a new quick disconnect is $18 at the parts store here so even that would be cheaper than a whole new line.
  12. #12 Re: Fuel Line O rings
    Michigan
    I would have gone that route too but Im soo afraid of splicing plastic fuel line...
  13. #13 Re: Fuel Line O rings
    Wichita
    ^^^This I did not know. Thx.
  14. #14 Re: Fuel Line O rings
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    There are NO problems what-so-ever with using a used fuel rail, but that doesn't have ANYTHING to do with his problem. The problem is the o-ring inside the quick-connect.
    I think there is some confusion in this thread. When SDGTP99's fuel line was replaced I bet they only replaced the plastic line that goes from teh hardline under the brake booster to the fuel rail. You can't buy them used because they get destroyed when getting removed.
    If you still need the o-rings when I get home from vacation at the end of next week I'll put a couple in an envelope for you, but you might not want to wait that long.
  1. fuel line nut rusted to fuel line!!
    By Pepino in forum General Tech Discussion
    Last Post: 08-12-2010, 08:25 AM
  2. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  3. Fuel Lines O rings
    By BDEGhost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-05-2010, 08:45 PM
  4. Fuel line disconnet
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2009, 08:22 AM
  5. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
