Very embarrassing to have to come here asking what I'm about to ask, I've pulled countless engines, trannies, rear ends and wrenched on many of my ****box cars over the years so I'm no noob when it comes to cars. A couple other random questions after my initial rant/dumbass confession.
Anyways...How in the hell are you supposed to jack up the car and set it on jackstands without the pinch weld folding over or the car falling off the jack? Maybe it's because I'm tired as **** from working my ass off all week and started my header/3.4 install at 6pm but I successfully dropped the car off of a jack for the first time in my life and nearly put it through the a/c compressor (jacking from the front, middle of the frame...Round. DUH) then I jacked up the car from the passengers side pinch weld where any other car is fine with it (using a 3 ton jack with a big flat jacking surface) and when I noticed that I was bending the pinch weld I lowered the car down... RIGHT ONTO THE JACKSTAND WHICH PUT A NICE HOLE IN THE BOTTOM OF MY DOOR!
So then I had my friend jack the car up from the control arm while I tried to position the jack stand right where it should go on the pinch weld and as he lowered the car I saw the weld starting to bend again and had him jack it back up.
I'm pissed because the un-installation of the stock manifolds was going all too smooth, I was actually having fun working on car for the first time in YEARS until the jacking became impossible.
Also I'm not happy to find out that the MPS pulley from ZZP is an 8 rib pulley, that is mentioned NOWHERE in that products description, but I see in the 8 rib conversion pulley description it says you can't use them without the MPS. I can only assume I have to get the matching 8 rib pulleys now right?
Should I rtv the headers or just the slip joints? I got SSAC headers and the gasket seems pretty good but I don't feel like taking these *****es off after I get them on.
Thanks in advance.
