Thread: Is this temperature normal?
Results 1 to 20 of 24
  1. #1 Is this temperature normal?
    GT Level Member Haulero's Avatar
    Gray Court, South Carolina. USA
    Well, ever since I bought my car I always wonder if this is normal in grand prix's or mine has a problem. this "problem" has been there for 3 years or more but never asked anyone. I don't remember this happened to my past cars
    First pic shows normal driving and second pic shows heavy traffic
  2. #2 Re: Is this temperature normal?
    That is the exact same as my car.
  3. #3 Re: Is this temperature normal?
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    when it is above 210 that is quite high. ur tstat is probbly shot
    silver 2003 Grand Prix GT List is on it's way to be updated
  4. #4 Re: Is this temperature normal?
    Just remember that he is in heavy traffic, with no air flow to the motor. Mine does the same thing and I am not worried one bit.
  5. #5 Re: Is this temperature normal?
    Yeah... this only happens in heavy traffic, stop and go.
  6. #6 Re: Is this temperature normal?
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    Mine does the same thing as well, no worries
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  7. #7 Re: Is this temperature normal?
    whoa, thats ****ed, looks like you have a 180* t-stat or a horribly worn 195 based on that.
    However, i can confirm the stock fan settings will get it get up to 220 before it takes serious action.
  8. #8 Re: Is this temperature normal?
    Nov 2008
    why does it wait till it gets that hot? its really not good for it to get about 200 does it
  9. #9 Re: Is this temperature normal?
    200 is 5 more than the stock t-stat temp....
    its called tolerances, they're very loose at GM for no good reason....
    I'd have it set to 205-210 if i were running a stock T-stat.
  10. #10 Re: Is this temperature normal?
    Nov 2008
    o iguess that i didnt realize that they were at 195 stock. that kinda makes sense then
  11. #11 Re: Is this temperature normal?
    This isn't a honda where stock is 170 lol
  12. #12 Re: Is this temperature normal?
    GTP Level Member SuperSport's Avatar
    Michigan
    Why does my temp gauge start at 160 and his starts at 100? What year did they change that?
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  13. #13 Re: Is this temperature normal?
    His is part of the first half based on the lines in the speedo.
  14. #14 Re: Is this temperature normal?
    HUDSON
    That is exactly what is it supposed to do, go up when sitting in traffic.
    Also, have to consider ambient outside temperature. The hotter it is outside, the less heat the cooling sytem can remove, so in hotter times like summer, you can expect to see it a little higger in extreme situations such as sitting in the middle of the interstate while traffic is stopped to clear a major crash, or waiting in line 20 cars deep in the Mcdonalds drive through at 3pm with Amazonian River Slothes taking the orders.
    And, that is not hot, still plenty of room before the red.
  15. #15 Re: Is this temperature normal?
    Feb 2008
    I think you're okay, but you may consider going ahead and changing your thermostat. Might as well put a 180* in there.
  16. #16 Re: Is this temperature normal?
    Quote Originally Posted by DanGTP View Post
    I may sound dummy but its ok lol... how do you change it? I'm sure it has not been changed in a long time anyways
  17. #17 Re: Is this temperature normal?
    dont change it unless youre tuning the PCM to turn the fans on sooner. otherwise youre wasting time and money.
  18. #18 Re: Is this temperature normal?
    May 2008
    Quote Originally Posted by QUICKSILVER462 View Post
    Take it u have been in that situation lmao...i have gone into the red becuase of that crap...but my tstat was bad too
  19. #19 Re: Is this temperature normal?
    I would change it out for a 195... aka a new fresh stock one. Especially if the car has some decent miles on it and its never been changed. Most people dont change it till it fails completely.
    It seems to be lacking in the proper open temp unless of course your temp sender is gone or inaccurate or the gauge is a POS like mine is.
  20. #20 Re: Is this temperature normal?
    GT Level Member GreyGhost's Avatar
    Nov 2009
    IL
    How many stages does the GP fans have?
    Use to the Thunderbird fans that have 2 speeds. When that second speed kicks in you know it on the Bird.
  1. What's normal operating temperature in traffic?
    By Z28 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2010, 09:23 AM
  2. Temperature Problems
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-19-2010, 10:55 AM
  3. What is the normal engine temperature?
    By noname in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-14-2010, 07:37 PM
  4. Normal Running Temperature
    By gorps in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2010, 09:06 PM
  5. Engine Temperature Normal Range...
    By Chris in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2009, 08:17 AM
