Thread: 92 Grand Prix radiator fans
Results 1 to 7 of 7
  1. #1 92 Grand Prix radiator fans
    North Idaho
    Short story: Bought inexpensive car for kids first vehicle & fixing up nicely to make safe...Latest issue, got a call from wife that the car was overheating w/ a/c on, she turned it over to heating & it dropped down nicely. When I took a look at it I noticed that the driver side radiator fan would cycle on, but not able to witness passenger side fan running. Is the passenger side an a/c condensor fan only? Do the 2 fans simply run @ different temps (driver side first, passenger side second)? Any quick tips to troubleshoot? Thanks, Dave
  2. #2 Re: 92 Grand Prix radiator fans
    check the grounds. poor ground could cause this
  3. #3 Re: 92 Grand Prix radiator fans
    North Idaho
    Check the ground where? At the plug into the fan?
  4. #4 Re: 92 Grand Prix radiator fans
    not sure since i'm not sure how that fan would be wired but trace all the wires and see if any are frayed.
  5. #5 Re: 92 Grand Prix radiator fans
    Charles City, IA
    Amazon.com: Power Probe III Ultimate 12 to 24 Volt Automotive Electrical Circuit Tester Kit: Automotive
    buy one of those. It helps a ton with electrical issues. Or run a jumper wire from the batter to the fan to see if you can get it to turn on.
    SMGPFC Two Nipple General
  6. #6 Re: 92 Grand Prix radiator fans
    North Idaho
    Do the two fans ever run independantly or do they always run simultaneously?
  7. #7 Re: 92 Grand Prix radiator fans
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    i had the same problem, I have a 99 grand prix gt and i noticed that when you turn the ac on both fans run! but i have never witnessed my fans working without the ac on.
  1. Grand prix GT side skirts on 97 Grand Prix SE
    By Carnes97SE in forum How To Write-Ups/Tech Tips
    Last Post: 11-17-2013, 05:17 PM
  2. Cheap 1-3/8" Radiator upgrade for your 97-03 Grand Prix [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 08-13-2010, 12:26 PM
  3. Radiator and Water Pump replacement 95 Prix SE Coupe
    By Soultempter in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-20-2009, 12:08 AM
