Thread: question
Results 1 to 9 of 9
  1. #1 question
    Joliet, IL
    should my car get 195-200* with a 180stat and proper fan settings? ive bled the system by just opening the bleeder and letting the car run.....coolant drips slowly from it but doesnt squirt out....helpy
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: question
    Its hot...you use the A/C...its pretty possible.
  3. #3 Re: question
    Outer Space
    mine can get there no problem, especially on these 99* weather days. Just check to make sure both fans work and levels are ok. No need to stomp it when your extra hot.
    02 GTP 13.6 @ 100mph - SOLD
  4. #4 Re: question
    Joliet, IL
    yeah i dont stop it but it is almost 100 here some days so prob just hot out but even when its 80 at night it still sits at 197...with no ac.
    00 Silvermist GTP
  5. #5 Re: question
    GTX Level Member real diehl's Avatar
    Salina, KS
    With my 160* I run close to 180 in the summer...so 20* over what your thermostat/fans are at isn't unreasonable. An OE t-stat would probably have you running around 215 on a hot day...like blue said accessories factor in also.
    signature removed for inappropriate content.
    -bio
  6. #6 Re: question
    Also...gotta figure humidity kicks your cars ass... especially these things.
  7. #7 Re: question
    Joliet, IL
    Ok good just makin sure.....and the humidity is out rageous by me lately humid and 95ish all week
    00 Silvermist GTP
  8. #8 Re: question
    Should be two things holding you back from running nearly T stat temps. Flow is the first. If you've never researched or checked out the coolant turn that happened in the LIM right under the TB, it can be a restriction. Secondly a thicker core radiator may be necessary to adequately cool.
  9. #9 Re: question
    Donating Users Warbeaver's Avatar
    St. Louis
    with fan turn ons, 180*, and EVERYTHING heat wrapped, mine still gets up to 195-200 if i sit at enough lights.
  1. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  2. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  3. Question: Supercharger question.....
    By nmaponte in forum General Tech Discussion
    Last Post: 03-12-2009, 01:04 PM
