Thread: diffucult warm start
Results 1 to 4 of 4
  1. #1 diffucult warm start
    Pa
    I have been having trouble getting the car to stay running after i shut it off after driving. I do not have any codes present, and the problem is very intermident. Today i had the fuel pressure guage connected as well as my scanner and here is what i found.
    1. Fuel Pressure drops down to almost nothing while engine is losing power.
    2. Once engine stops running pressure returns to normal.
    With scan tool recording i noticed when it is about to stall the following PIDS.
    1. GM.ENGINE.12SOL_OPEN_SHORT aka 1-2 Solenoid open/shot to groung reads YES
    2. GM.ENGINE.23SOL_OPEN SHORT aka 2-3 solenoid open/short to groung also reads YES
    When compared to earlier recorded logs these always say no, so can someone give me any ideas what this could be. Also i just replaced the iac valve, and also removed the throttle body for a complete cleaning.
  2. #2 Re: diffucult warm start
    louisiana
    i think i am having the same problem. does your car start fine when it has time to cool down like overnight. and i have a brand new fuel pump and relays
  3. #3 Re: diffucult warm start
    Joliet, IL
    crankshaft position sensor.
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  4. #4 Re: diffucult warm start
    Pa
    found out i had a broken wire on the back of the fuse panel for pcm and sensor ground. Just for future referane it is the black cell and wires b1 and b3
  1. Starts then dies warm
    By trailshredder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2010, 07:02 PM
  2. Trans does not want to shift out of 1st until warm
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-30-2010, 11:45 AM
  3. warm up
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2009, 09:19 PM
  4. 2003 GT Won't Start when Engine is Warm...have to wait 45 min
    By LS2 GTO in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-17-2009, 12:30 PM
  5. Rough on warm start
    By hacket in forum General Tech Discussion
    Last Post: 03-22-2009, 12:01 PM
