Thread: Help me with my cooling issues.
Results 1 to 15 of 15
  1. #1 Help me with my cooling issues.
    In Memoriam Rocket468's Avatar
    Yukon, Oklahoma, United States
    For some reason my fans only will come on if i turn my a/c on or if i turn on my manual switch.
    I am looking for the instructions for the manual cooling fan how to. I remember blacknblack or soemthing like that had a really good how to.
    I just need to go over what i have my fan keep quit working by pcm controll and this is getting old.
    My EX wifes other car is a broom.
  2. #2 Re: cooling fan manual switch
    Donating Users Ibwrong's Avatar
    Oklahoma City
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  3. #3 Re: cooling fan manual switch
    Banned - Busted For Scamming
    Feb 2009
    Its probably your ect sensor, its a dual sensor so your gauge will probably still work. If you havent checked that already, that is. You can view the coolant temp PID with the scan tool.
  4. #4 Re: cooling fan manual switch
    Yea i think its is my coolent sensor. someone has my scan tool.... but i have had this issue for years. My fans only come on if i turn the a/c on. I unpluged the sensor and my fans still do not come on.
  5. #5 Re: Help me with my cooling issues.
    Largo, Florida, United States
    was that the coolant level sensor? or a different one?
  6. #6 Re: Help me with my cooling issues.
    May 2008
    staten island,NY
    coolant temp sensor located under the T-stat, tapped into the LIM
  7. #7 Re: Help me with my cooling issues.
    Quote Originally Posted by QwikGT View Post
    thanks, just wanted to make sure it wasn't the one i was going to disable lol (coolant level sensor)
  8. #8 Re: Help me with my cooling issues.
    replaced the temp sensor under the intake manifold. my cooling fans still do not turn on. Except on low when i turn the a/c on.
    I tested the relays they test good to. I even swaped out my pcm for another.
  9. #9 Re: Help me with my cooling issues.
    Any other idea?
  10. #10 Re: Help me with my cooling issues.
    GTP Level Member Scimmia's Avatar
    QCA, IA
    You need to see what ECT the computer is seeing. Get that scanner back.
    2001 Buick Regal LS - Almost Stock
  11. #11 Re: Help me with my cooling issues.
    pcm is seeing proper ect.
  12. #12 Re: Help me with my cooling issues.
    Charles City, IA
    Must have a bad wire somewhere.
    SMGPFC Two Nipple General
  13. #13 Re: Help me with my cooling issues.
    yea, but the a/c works the fan. just not the ecu.
  14. #14 Re: Help me with my cooling issues.
    QCA, IA
    Stock PCM? If the computer's seeing the correct ECT, it's not a sensor problem. I assume the GP's the same as the Regal in that the HVAC control just reports to the PCM for AC, so if the fans are turning on with the AC, it's not the wiring there, either.
  15. #15 Re: Help me with my cooling issues.
    Jul 2010
    Did you ever find a solution to your problem, I have the exact same thing happening to my daughters car.
  1. 99 cooling fan issue
    By spidyrmen in forum General Tech Discussion
    Last Post: 04-23-2013, 05:04 PM
  2. Cooling Fan Switch location?
    By shaner in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-22-2012, 10:15 AM
  3. A/C not cooling
    By VolsFan in forum General Tech Discussion
    Last Post: 05-16-2010, 08:54 PM
  4. Cooling Problem
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 06-17-2009, 10:53 AM
  5. Cooling
    By Davisgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2009, 07:30 PM
