Thread: I have the opportunity to buy back my gtp.
Results 1 to 10 of 10
  1. #1 I have the opportunity to buy back my gtp.
    SE Level Member RichCresci's Avatar
    Jul 2008
    I haven't been on the forums in about 2 years because I sold my 99 GTP when I blew the trans. The guy I sold it to put a new trans in it, then sold it to his friend, now it's for sale yet again. I have the opportunity to possibly pick it up for $600 because from what I understand it smokes alot. What I'd like to do is pull the motor and build it. It ran a 14 flat when I had it and I like to make it a 13.0 second car. I'm 19 and I feel like I know alot about engines for my age but obviously not enough to tackle this project on my own. How hard is it to pull the motor and trans? Any idea what a shop would charge to rebuild the motor just in labor? I'd really love to turn this thing into a total killer, but I am a student and I'd like to keep it on a $2500 budget less $600 for the car itself so $1900 total to build the motor and make sure the trans will hold the power. Any thoughts? Thanks again
    1999 GTP Sedan - 3" SLP Headers, K&N Intake, VS cam, poly mounts, ZZP pcm, 3.4" mod pulley, Thrasher shift kit, Pypes racepro, GMPP Handling kit + Trailing arms, Gauges(aeroforce scan, boost, oil psi)
  2. #2 Re: I have the opportunity to buy back my gtp.
    Largo, Florida, United States
    Quote Originally Posted by RichCresci View Post
    600$ is a good price. but pulling all that out is extremely difficult for the unexperienced. I myself just put a new engine in my car and rebuilt it and it took me alittle over a month
    and 1800 for the engine (65k)
    200$ for gaskets
  3. #3 Re: I have the opportunity to buy back my gtp.
    Jul 2008
    Does the whole subframe have to be dropped or can just the motor and trans be pulled?
  4. #4 Re: I have the opportunity to buy back my gtp.
    Nov 2009
    Grand haven
    Buy it back.. Yes dropping the cradle makes it a lot better.
  5. #5 Re: I have the opportunity to buy back my gtp.
    Jul 2008
    But that brings me back to the topic of my level of skill and the fact that it's all going to be done in my driveway. Would this be an appropriate starting point for an aspiring mechanic?
  6. #6 Re: I have the opportunity to buy back my gtp.
    a transmission swap is not where you want to start with a car unless you have some knowledge on it already. ive done it, but i used a lift at my brothers place of employment. if i had to do it in a driveway it would have been a hundred times harder.
  7. #7 Re: I have the opportunity to buy back my gtp.
    Jul 2008
    From what I understand the trans slips, but I can't be certain. I have to talk to the kid who redid the trans and obviously test drive the car as-is.
  8. #8 Re: I have the opportunity to buy back my gtp.
    i wouldnt start at the trans from not knowing dick about them.
  9. #9 Re: I have the opportunity to buy back my gtp.
    Jul 2008
    regardless of the mechanicals of it, if it runs and drives I can't get burned for $600, can I?
  10. #10 Re: I have the opportunity to buy back my gtp.
    Charles City, IA
    IF it blows up on the way home I would consider that burned. You should be fine buying it at the price.
    SMGPFC Two Nipple General
  1. Thank you for the opportunity to join
    By Cobra in forum Introductions/Noob Questions
    Last Post: 02-27-2010, 08:52 PM
  2. Im back
    Last Post: 01-13-2010, 04:26 PM
  3. Keep or Go Back
    By stlmo_gtp in forum Audio, Security & Visual Electronics
    Last Post: 07-28-2009, 01:36 PM
  4. need help getting my back window back on track
    By GrandPrixGT00 in forum Visual/Body Modifications
    Last Post: 06-15-2009, 04:06 PM
  5. IM back at it
    By GTPRiley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2009, 11:51 PM
