Thread: 2006 dash pull?
Results 1 to 6 of 6
aries83 2006 dash pull? 05-01-2010, 09:31 AM
aries83 Re: 2006 dash pull? 05-01-2010, 11:42 AM
checkinpox Re: 2006 dash pull? 05-05-2010, 09:54 AM
vailskier3 Re: 2006 dash pull? 05-11-2010, 08:40 AM
aries83 Re: 2006 dash pull? 05-12-2010, 11:48 AM
c40verload Re: 2006 dash pull? 05-10-2010, 04:11 PM
  1. #1 2006 dash pull?
    Indianapolis, IN
    Hey, this is probably a stupid question but I would rather ask than end up breaking something.
    I am trying to pull the dash trim around the radio, climate control, and ignition. Once I get to the ignition it just stops coming off. I was wondering if I just need to keep pulling (and hope nothing breaks) or if I am missing a step to remove this panel.
    It might be better to also ask about the radio. I am trying to see if there are any aux connections on the back of my radio, it is the standard equip radio. I am looking to see if there is a way to plug an I-Pod into the back of the radio with a kit rather than use a wireless connection because of poor sound quality.
    Thanks,
  2. #2 Re: 2006 dash pull?
    Indianapolis, IN
    ok, never mind. I got impatient and just started pulling and yes the panel pops off with a little care around the ignition. unfortunatly the radio does not have any auxilary inputs on the back so I have to do more research on what to use to install an ipod interface. I will repost once I figure something out for the ipod users out there.
  3. #3 Re: 2006 dash pull?
    Canada
    check out Metra electronics for a kit for installing i-pod for factory radio
  4. #4 Re: 2006 dash pull?
    Jul 2008
    Tampa, FL
    Quote Originally Posted by aries83 View Post
    you should have searched the forum first. there is tons of info on this already...
  5. #5 Re: 2006 dash pull?
    Indianapolis, IN
    I will check them all out thanks. I did do a search but it kept pulling up all kinds of crazy stuff that did not apply. It was either spend to much time rumaging to find the right post or get the job done...
  6. #6 Re: 2006 dash pull?
    SE Level Member c40verload's Avatar
    Allentown, PA
    Check out crutchfield.com they have kits to hook an ipod up to a factory radio
  1. 0-105 mph pull
    By gtpinsc in forum Off Topic Discussion
    Last Post: 05-02-2010, 09:32 AM
  2. If your bored pull this off at wal mart
    Last Post: 03-08-2010, 08:04 PM
  3. got pull over today
    By nemesis in forum The Rant Forum
    Last Post: 06-25-2009, 02:59 PM
  4. 911, Help Im locked in my car... Oh, pull lock? um Thanks!
    By FoSHO99 in forum Off Topic Discussion
    Last Post: 04-01-2009, 11:07 PM
  5. pull engine?????
    By kingd44 in forum Off Topic Discussion
    Last Post: 08-10-2008, 09:12 PM
