Thread: Bouncing projectors
Results 1 to 16 of 16
  1. #1 Bouncing projectors
    Minnesota
    So i know im not the only thats had or has this problem iv been looking around to find out how to fix this i heard weather stripping on the bottom of em works is this true? andbody got any good ideas. pics would be awesome thanks
  2. #2 Re: Bouncing projectors
    SE Level Member bensett004's Avatar
    michigan
    not tryin to jack ur thread man but can u run hid's with projectors?
    fwi, kn filter, 3 in down pipe, power log, 180* thermostat, 10000k hids and soon to come a dhp pcm
  3. #3 Re: Bouncing projectors
    Willoughby, Ohio
    weather stripping worked for me, ive heard that a junkyard trunk seal off another GP will work great too
  4. #4 Re: Bouncing projectors
    Minnesota
    cool you got any pics of how you did that?
    and yea you can have HIDs with projectors
  5. #5 Re: Bouncing projectors
    Willoughby, Ohio
    there are pick in my photobucket link but no close ups, i bought this regular foam type weather stripping from advance auto for like $2 and i doubled it up to the bottom of the headlight so it rests against my bumper
  6. #6 Re: Bouncing projectors
    Norristown, PA
    projectors bouncing? what else is new
  7. #7 Re: Bouncing projectors
    SE Level Member slow94formula's Avatar
    MN
    Mine has the foam to help brace them, but they still manage to bounce. Definitely not near as bad as they used to, but still. I think there is a thread on the antibounce mod in the how to section.
  8. #8 Re: Bouncing projectors
    MN
    Nevermind... It wasn't in the how to section on this website. http://www.clubgp.com/newforum/tm.as...mode=1&smode=1
  9. #9 Re: Bouncing projectors
    ^^Link no work
  10. #10 Re: Bouncing projectors
    MN
  11. #11 Re: Bouncing projectors
    michigan
    just got some projetors....it says no hid....what happens if i use them? jw....
  12. #12 Re: Bouncing projectors
    Quote Originally Posted by bensett004 View Post
    nothing. your light output will go up. it just says youre not supposed to run HIDs because they are halogen style projectors.
  13. #13 Re: Bouncing projectors
    michigan
    sweet i was hopeing i didnt waste 14 bucks for new bulbs....i had stock hid but they dont fit projectors....i was pissed
  14. #14 Re: Bouncing projectors
  15. #15 Re: Bouncing projectors
    Willoughby, Ohio
    its an HID kit. you can buy Xenon bulbs, but HIDs are 2 bulbs 2 ballasts and wiring
  16. #16 Re: Bouncing projectors
    michigan
    yah i know, i have ballast i b ought new bulbs for them....i had 900? stock bulb size, i just bought the h1 bulbs for my ballast
  1. high-pitched whistle and bouncing idle
    By CSteen85 in forum General Tech Discussion
    Last Post: 04-28-2010, 07:58 AM
  2. Fixing Headlights' Bouncing
    By vega in forum Visual/Body Modifications
    Last Post: 02-20-2010, 07:31 PM
  3. 94 GTP gas smell and bouncing idle
    By rw53104 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 02-17-2010, 02:21 PM
  4. Projectors and HID's?
    By dagger in forum Audio, Security & Visual Electronics
    Last Post: 05-18-2009, 05:20 PM
  5. 04 GTP headlights bouncing and load rear end
    By BrianA in forum General Tech Discussion
    Last Post: 02-03-2009, 07:25 PM
