Thread: spark plug wire question
Results 1 to 9 of 9
  1. #1 spark plug wire question
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    was showing off motor at night and saw spark coming from all the plug wires at the plugs when i reved the motor. a friend said it was just static discharge and that it was normal. what do u all think?
  2. #2 Re: spark plug wire question
    Donating Users Warbeaver's Avatar
    St. Louis
    well idk, but normally that is called "arching" and its usually from moisture being in the boots. Thats why they make di-electric grease to put in the boots of the plugs so they dont do this. a set of PRJ wires was doing this, and it turned the terminal on the coil pack brown.
    idk, but check the insides of the boots. i have never seen my wires spark like that out of normality
  3. #3 Re: spark plug wire question
    SE Level Member Feather Head's Avatar
    Wausau
    Saw that on a Jetta I worked on and it had a misfire in the rain
    99 GT - SD Headders, EGR delete, Custom Tune, HV3
    70's Sears-Fully built OHV Briggs Single
  4. #4 Re: spark plug wire question
    Feb 2010
    somewhere cold
    neither have i as i only noticed cause it was dark out and i saw a flickering light on my firewall and then saw it on all the plugs. i would have been alarmed if not for the fact that all the plugs were doing it. hard for all the wires to fail at one time
  5. #5 Re: spark plug wire question
    Apr 2009
    stockton ca
    yea no thats bad definatly bad definatly check the boots
    had an old civic do that once fixed the problem happened to be a bad wire and arched through 2 other wires
  6. #6 Re: spark plug wire question
    Charles City, IA
    time for new wires
    SMGPFC Two Nipple General
  7. #7 Re: spark plug wire question
    Feb 2010
    somewhere cold
    then new wires it is...left message for the guy that use to sell/work at the moroso plant but havent got a response. do u all know if he is still selling them?
  8. #8 Re: spark plug wire question
    Apr 2009
    stockton ca
    last i saw he was still selling usually takes a couple days for him to get back to people i bought mine through him
  9. #9 Re: spark plug wire question
    Feb 2010
    somewhere cold
    Quote Originally Posted by TorqueAutoMotiv View Post
    and how do u feel about them?
  1. Spark Plug Question.
    By DnaProdigy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2011, 09:45 PM
  2. Spark Plug question
    By Kenny75k in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2010, 09:04 PM
  3. spark plug wire order help
    By SloEvil in forum General Tech Discussion
    Last Post: 08-16-2009, 04:19 PM
  4. Corolla spark plug wire change (general maint. question)
    By 04CompG in forum Off Topic Discussion
    Last Post: 09-16-2008, 03:21 PM
  5. Spark plug question
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2008, 05:36 PM
