Thread: Fuel Filter?
Results 1 to 12 of 12
  1. #1 Fuel Filter?
    SE Level Member RideMr2's Avatar
    Memphis
    Hello;
    I purchased a 2007 Grand Prix GT with 3.8L Supercharged.
    I was trying to get a fuel filter for it, 59,000 miles, but can't find one.
    The dealer mentioned something about it being in the fuel tank?
    If so, can I still change it?
    Thanks
  2. #2 Re: Fuel Filter?
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    iirc 04+ fuel filters are NS
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  3. #3 Re: Fuel Filter?
    Charles City, IA
    04-5 have them 06+ do not
    SMGPFC Two Nipple General
  4. #4 Re: Fuel Filter?
    Donating Users dirtmaster88's Avatar
    Sheboygan, WI
    NS?
    2004 GTP CompG - 3.6" ZZP MPS, K&N CAI, 180* Tstat, SSAC Headers, ZZP Flex, high flow cat, borla exhaust, DHP/danthurs tune, AL104s, ZZP Wires, alt re-wire, slotted/drilled rotors, 35% tint, alpine amp + sub
  5. #5 Re: Fuel Filter?
    Dec 2008
    London, Ontario
    non serviceable
  6. #6 Re: Fuel Filter?
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    im wondering this too. i have an 04. is it in the tank. never really looked
  7. #7 Re: Fuel Filter?
    GT Level Member Whitehispanic's Avatar
    Westborough
    The fuel filter is right in front of your left rear tire it looks like this http://www.autopartswarehouse.com/im...gs/HAGF367.jpg one suggestion i have if your gonna do it your self spray wd40 on it other wise your gonna have such a hard time trying to take that off its insane cause i just changed my and it was a pain cause i added wd40 after i tried to do so save ya self time and do it before.
    *sig too tall*
  8. #8 Re: Fuel Filter?
    Feb 2010
    indianapolis
    Quote Originally Posted by Whitehispanic View Post
    right on dude. changin it this weekend
  9. #9 Re: Fuel Filter?
    on the fitting end, my fitting was siezed to the fuel line so i had to spin the filter and the mounting bracket to get the damn thing out.
  10. #10 Re: Fuel Filter?
    Charles City, IA
    I always try to spin the filter side and just hold the line end with a good line wrench. Less chance of stripping it.
  11. #11 Re: Fuel Filter?
    i had no choice in that matter.... But I'll end up doing it that way regardless from now on.
  12. #12 Re: Fuel Filter?
    Memphis
    Found this ; why no in-line fuel filter? - Chevy HHR Network
    GM has stopped putting inline filters in some models since 2004. Other manufacturers have been doing it longer. The fuel sender assembly (pump/regualtor/sock/level sensor) inside the tank has a container on the bottom of it about the size of 1/2 coffee can. All the fuel pick up components are inside of this container. It has a small intake port in the very bottom that filters the bigger debris so that the fuel that is filling the container is fairly clean. The fuel fills the container and a sock(filter) is used at the end of the fuel pumps pick-up tube. Smaller debris that makes it to the sock is then filtered by the sock before entering the fuel pump and simply falls to the bottom of the container.
    Todays pumps are much more robust then pumps of old also. We still see more failures of the old style pumps with inline fuel filters then we do of the newer style.
    GM calls this a self cleaning system. Any debris that does not go into the canister of the fuel pump assembly falls to the bottom of the tank and any debris that the sock stops falls to the bottom of the canister when the fuel pump is shut off. We are talking very small amounts of debris here too.
  1. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  2. Fuel Filter
    By newmarket23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-23-2009, 09:04 PM
  3. Fuel Filter on 03 3.8
    By Lucid Violence in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-19-2009, 01:09 AM
  4. fuel filter.........
    By julian2875 in forum General Tech Discussion
    Last Post: 07-21-2009, 12:48 PM
  5. fuel filter
    By uti grand prix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-27-2008, 11:46 AM
