Thread: How to stop chiming from TC,ABS messages
Results 1 to 4 of 4
what9612 How to stop chiming from... 05-04-2010, 04:49 PM
dirtmaster88 Re: How to stop chiming from... 05-07-2010, 08:45 AM
Myprixxx Re: How to stop chiming from... 05-09-2010, 04:27 AM
what9612 Re: How to stop chiming from... 05-10-2010, 05:24 AM
  1. #1 How to stop chiming from TC,ABS messages
    michigan
    my gf has a 2004 gtp and has all the error messages when first started up. im not trying to stop the messages just the stop the hundred chimes when i start it. if i take the dic off it doesnt chime, is there a wire i can cut off the back of that and solder back later after the car is fixed?
  2. #2 Re: How to stop chiming from TC,ABS messages
    Donating Users dirtmaster88's Avatar
    Sheboygan, WI
    The 10 seconds of chimes really bothers you that much that you want to cut the wiring? Why not just get a new hub bearing and actually fix the real problem?
    2004 GTP CompG - 3.6" ZZP MPS, K&N CAI, 180* Tstat, SSAC Headers, ZZP Flex, high flow cat, borla exhaust, DHP/danthurs tune, AL104s, ZZP Wires, alt re-wire, slotted/drilled rotors, 35% tint, alpine amp + sub
  3. #3 Re: How to stop chiming from TC,ABS messages
    SE Level Member Myprixxx's Avatar
    Apr 2008
    Decatur, IL
    Quote Originally Posted by dirtmaster88 View Post
    X2 look around in the FS section.. i got a brand new hub for 50bucks shipped to my door and took me 2 hours tops to put it on and get that fixed.. cutting a wire and then soldering it sounds like more work than its worth.. buutt different strokes for different folks i guess
    i knew this guy wasn't b/sing.
    michigan people have better stuff to do, like finding jobs or avoiding robbery.
    quoted from noreasonwhyy
    GenV, Full sized I/C, HAI, 3.0 MPS, N* TB
  4. #4 Re: How to stop chiming from TC,ABS messages
    michigan
    I would obvoiusly like to fix the problem, instead of rigging but I thought if it was as simple as cutting 1 wire then ill do it for now. Anyways from all the scans we have got everything is pointing to the actual abs module.
  1. 2004 GP gauges stop working and warning messages come on
    By mark1491 in forum General Tech Discussion
    Last Post: 12-20-2009, 02:18 AM
  2. disable dic messages?
    By BoostedComp in forum 04+ Specifics
    Last Post: 12-05-2009, 02:29 PM
  3. Is it ever going to stop!!!
    By SlowM90 in forum Off Topic Discussion
    Last Post: 07-30-2009, 03:17 PM
  4. Driver Messages
    Last Post: 07-09-2008, 11:20 PM
  5. CPACGP member chiming in
    By Mr. Pig in forum Introductions/Noob Questions
    Last Post: 01-04-2008, 07:29 AM
