Thread: Would this work?
Results 1 to 3 of 3
  1. #1 Would this work?
    SE Level Member GTPcoupe's Avatar
    Feb 2010
    Canada
    Well I'm a bit of a wiring newbie, but I believe this should work. I have my boost gauge setup and I just need to do the lighting for it. I want to power the lighting same way pretty much as I did for my Aeroforce gauges.
    If I run the power wire to an add-circuit by little fuse plugged in where the steering wheel control illumination fuse is, would that work same was as if I would have spliced into the dimmer switch? Also, I'm not sure where I should screw in the ground wire? Sounds pretty simple, but I just wanted to be sure.
    '99 GTP coupe - Growing mod list/summer car
    '98 GTP Sedan - Winter ride, 315,000+kms and going strong!
  2. #2 Re: Would this work?
    Feb 2010
    Canada
    The fuse used for the steering wheel controls illumination is 2A. What should I plug in the other slot for the boost gauge light? Another 2A? 10?
  3. #3 Re: Would this work?
    Nov 2009
    Grand haven
    The gray wire off your dimmer switch. pull your headlight switch turn it up side down and it is the second wire on the bottom row lil gray one..
  1. Will these work??
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 09-28-2009, 08:00 PM
  2. Will this work on my 07 GP?
    By tino153 in forum General Tech Discussion
    Last Post: 05-28-2009, 04:07 AM
  3. Work
    By TheOtherNick in forum The Rant Forum
    Last Post: 10-14-2008, 09:30 PM
  4. G.I. In Fab work
    By J_Ferguson in forum Off Topic Discussion
    Last Post: 06-27-2008, 10:33 AM
