Thread: P0135 - replace o2 sensor?
Results 1 to 11 of 11
  1. #1 P0135 - replace o2 sensor?
    Donating Users dirtmaster88's Avatar
    Sheboygan, WI
    I'm not sure if it's related but I went from a 3.4 pulley to a 3.6 and a week later I'm throwing a P0135 code: Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1). I also have a slight exhaust leak in my headers (have had that for awhile now). When scanning at idle the o2 is reading around 800 and if I get on the gas it's 930+. This would lead me to believe that the sensor is working if it can get readings. Car has 84k miles.
    1) Do you think my front o2 is actually bad or could it be something else?
    2) If I do replace the o2, what brand should I get? AC Delco, Bosch, Denso?
    Thanks
    2004 GTP CompG - 3.6" ZZP MPS, K&N CAI, 180* Tstat, SSAC Headers, ZZP Flex, high flow cat, borla exhaust, DHP/danthurs tune, AL104s, ZZP Wires, alt re-wire, slotted/drilled rotors, 35% tint, alpine amp + sub
  2. #2 Re: P0135 - replace o2 sensor?
    Outer Space
    Fix your exhaust leak, and check the o2 wires... make sure they aren't melted or boogered up.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: P0135 - replace o2 sensor?
    Jersey
    i get that code all the time, its a brand new 02 sensor on my pacesetters. IMO the headers are causing a false code.
    16' wrx sti- stock
  4. #4 Re: P0135 - replace o2 sensor?
    Sheboygan, WI
    Quote Originally Posted by 99prixgt View Post
    Must be. I fixed my exhaust leak, looked over all the wiring, and replaced the front o2 with a brand new denso. Cleared the code but it's still coming back. I tried searching the various forums for posts on this code and wasn't able to find much information. I would think there would be many more posts on this if it really was caused by the headers. I'm not sure where to go from here. Suggestions anyone?
  5. #5 Re: P0135 - replace o2 sensor?
    Sheboygan, WI
    o2 wires are fine. It's now throwing a P0030 code as well. Ordered a Denso sensor from autozone, will be putting it in tonight. Car has 84k miles so it's not a bad thing to change it now anyways even if it is still good. Been getting super ****ty gas mileage the past few months too....
  6. #6 Re: P0135 - replace o2 sensor?
    Sheboygan, WI
    TTT
    still having problems
  7. #7 Re: P0135 - replace o2 sensor?
    Apr 2009
    stockton ca
    is there any way to simply put in a new o2 bung further down the pipe maybe? and just bolt off the first bung
  8. #8 Re: P0135 - replace o2 sensor?
    Portland Oregon
    I'm gettin the same codes, p0135 mostly and an occasional p0030. I had to extend the 02 harness because of the pacesetter header bung location. It wa fine until I melted the wires together on a club cruise. Since then I have replaced the wires but same thing. I'm gonna get a new 02 sensor myself and if it doesn't go away I'm just gonna program the codes to no report.
  9. #9 Re: P0135 - replace o2 sensor?
    Jul 2010
    Dubuc, SK
    I get the same thing on my pacesetter headers, and a few other 02 related codes. The codes will be erased when my zzp pcm comes in hopefully.
  10. #10 Re: P0135 - replace o2 sensor?
    I dont even think dirtmaster posts here anymore,
    heating circuit means you need a new O2 sensor or the wiring needs to be checked.
  11. #11 Re: P0135 - replace o2 sensor?
    Sheboygan, WI
    Today was the first really cold morning I had to drive my car and for the first time since I can remember I did not have a check engine light on my 15 min drive to work. It seems like this code is only present during warmer weather, or maybe just a coincidence? Either way, I'm going to have that code deleted out of my PCM on Monday so I won't have to deal with it again.
    I think it's safe to say that the headers are causing the code. Not that you still shouldn't look at the fuse/wiring/o2 sensor though.
  1. Replace DIC bulbs??
    By SDGTP99 in forum General Tech Discussion
    Last Post: 05-12-2013, 10:14 PM
  2. p0420 code, which o2 sensor do i replace?
    By Golman76 in forum General Tech Discussion
    Last Post: 02-15-2010, 10:50 PM
  3. Should I and what to replace??
    By torq455 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-28-2009, 08:13 PM
  4. what do i need to replace
    By guy87 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-27-2009, 07:30 PM
  5. How Do I Replace the FRP?
    By TZ250 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-27-2008, 11:07 PM
