Thread: abs light!!
Results 1 to 7 of 7
  1. #1 abs light!!
    roselle
    i changed both of my bearing hubs/ abs sensors and still once in a while the light will come on--abs/track off what else could be doing this thanks
  2. #2 Re: abs light!!
    Charles City, IA
    rears, abs module have the code read.
    SMGPFC Two Nipple General
  3. #3 Re: abs light!!
    roselle
    the back ones could be bad too
  4. #4 Re: abs light!!
    GTX Level Member colindunn's Avatar
    Aurora, IL
    i replaced both my front hubs. they were bad anyways. but the light was still on so i had it scanned and its the whole module..any connections or something i could test to get it working again? or does the whole thing need to be replaced. its not cheap.
  5. #5 Re: abs light!!
    Edmond
    Did you check the wiring harness? Mine was sheered off and cut through the wires needed to be replaced. Sometimes you don't get the wires hooked back up properly they can become loose and find many ways to get damaged. I am still looking to replace mine, I have rewired the harness myself by splicing the wires, but they usually come un-done after a couple of days...
  6. #6 Re: abs light!!
    Aurora, IL
    Quote Originally Posted by SMOKIN GTP View Post
    the wiring harness as in the large plug that plugs into the abd module? i took it off and cleaned it. i should check for broken wires there too?
  7. #7 Re: abs light!!
    Edmond
    Well there is a clip that holds the connectors in place. My clip came loose and fell down causing it to some how get caught and it sheered through one of the wires that leads back to your harness. I tried splicing the wires and it works, but for some reason the keep pulling loose. So I have given up on the harness for now. Just gotta deal with the ABS light and the trac control off....
  1. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  2. my 4th brake light and 3rd reverse light
    By HART in forum Visual/Body Modifications
    Last Post: 11-05-2009, 01:33 PM
  3. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
  4. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
