Thread: Door handle
Results 1 to 2 of 2
  1. #1 Door handle
    mich
    I have a 99 gt and the door handle works but doesnt retract . After u pull it The door opens but handle doesnt go back to home position. Is there a broken spring poss. I have the inner door panel off but how do I fix it ??
  2. #2 Re: Door handle
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    mine do it alos and the handle is broke where the spring would sit, its plastic and when u open the door up take out the handle u can see it it broke and about the only way to fix it is to maybe design something yourself, or replace the handle. both mine do it i just push them down almost natural lol
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  1. Need help with a handle
    By thenervemann in forum Visual/Body Modifications
    Last Post: 02-08-2010, 09:31 AM
  2. engine can't handle load...
    Last Post: 05-02-2009, 02:51 PM
  3. How much N2O can a stock 3800 handle?
    By Quicklynx in forum General Tech Discussion
    Last Post: 10-27-2008, 08:38 AM
  4. Need help with the outside handle on the door =(
    By thenervemann in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2008, 07:52 PM
