Is there a low pressure switch I can jumper to get the compressor to turn on so I can recharge the A/C (had to fix a leak)?
I noticed the A/C wouldn't turn on one day (the light won't turn on when I push the button, all fuses are good) and I found a leaky schrader valve at the service port. It still had refrigerant, but was low. I fixed the leak, and now have to get it recharged. I'll pull a vacuum and suck in a can, followed by another sitting in hot water (to boost the pressure), but will that give me enough pressure to allow the system to be turned on?
Thanks!
