Thread: 2004 Grand Prix GTP Overheats
Results 1 to 3 of 3
GTP4JR 2004 Grand Prix GTP Overheats 06-06-2010, 06:59 PM
937Crizzle Re: 2004 Grand Prix GTP... 06-06-2010, 07:29 PM
VictorSmalls Re: 2004 Grand Prix GTP... 06-06-2010, 08:22 PM
  1. #1 2004 Grand Prix GTP Overheats
    Jun 2010
    California
    I have a 2004 GTP with a little over 65,000 original miles. About 6 months ago the normal tempature reading started to rise.....engine was running hotter with normal driving. Mechanic replaced the thermostat, temperature sensor and said the radiator showed temp differences (possible has some blockage) so the radiator was replaced. In the past I could not see water dripping, no steam, but I was loosing coolant / water (always had to add a little water)
    Today for the 1st time I had to pull over for 10 minutes to let the engine cool....dashboard warning came on for overheating. Turned on the heater...no heat. Just let the car cool, checked again, no heat, and I do have a small puddle under the car, passenger side and I could see water dripping on the same side.
    What problem to we have? Water pump? What causes no heat?
    Thanks
  2. #2 Re: 2004 Grand Prix GTP Overheats
    Donating Users
    sabina,oh
    More than likely the water pump. Its prolly leaking out of the weep hole in the casting
  3. #3 Re: 2004 Grand Prix GTP Overheats
    GT Level Member VictorSmalls's Avatar
    Dec 2008
    Tyrone, PA
    No heat = missing a lot a fluid. Find out where that puddle is coming from.
    Retired
    Turbo'd
  1. 2004 Grand Prix
    By freightliner009 in forum General Tech Discussion
    Last Post: 03-07-2011, 01:49 AM
  2. 2004 Grand Prix L26 P0128
    By Cougar281 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-03-2009, 09:26 PM
  3. 2004+ Grand Prix Headlights
    By MuTaLiZeD in forum Visual/Body Modifications
    Last Post: 10-18-2009, 09:28 PM
  4. 2004 Pontiac Grand Prix
    By davma1 in forum General Tech Discussion
    Last Post: 08-31-2009, 08:36 AM
  5. 2004 Grand Prix HUD
    By l3enner in forum Audio, Security & Visual Electronics
    Last Post: 07-14-2009, 03:04 PM
