Thread: what exactly is WOT?
Results 1 to 20 of 20
  1. #1 what exactly is WOT?
    GT Level Member wlmrt6's Avatar
    Sterling
    im looking at getting an intense racing pcm and they are asking me options for WOT ignition timing tables.... what am i being asked. i use only 93 octane gas no less and if i race i have a booster in it. whats the difference in the degrees?
  2. #2 Re: what exactly is WOT?
    WOT = wide open throttle aka "pedal to the metal" or "give'n 'er"
  3. #3 Re: what exactly is WOT?
    West Side Michigan
  4. #4 Re: what exactly is WOT?
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    Quote Originally Posted by nawarkk View Post
  5. #5 Re: what exactly is WOT?
    Sterling
    ok so what should i put for my options there??
  6. #6 Re: what exactly is WOT?
    swift current,sask.
    Just keep the stock tables.
  7. #7 Re: what exactly is WOT?
    Sterling
    what would i benefit from increasing them?
  8. #8 Re: what exactly is WOT?
    Omaha, NE
    Quote Originally Posted by wlmrt6 View Post
    What are your mods?
  9. #9 Re: what exactly is WOT?
    West Side Michigan
    I asked a stupid question lol so I edited it and took it out.
  10. #10 Re: what exactly is WOT?
    Sterling
    im getting a 3"down pipe with high flow cat, intake, 180* tstat at the same time i get the tune.
  11. #11 Re: what exactly is WOT?
    Sterling
    i also have an 05 gtp if ya need to know
  12. #12 Re: what exactly is WOT?
    Step 1: Choose what company you want
    Step 2: Buy the PCM
    Step 3: Keep everything normal...don't tell you you want extra crap because you don't have enough mods for it
    Step 4: wait
    Step 5: Get it in the mail and install and enjoy
    Step 6: To go faster, get a custom tune...don't deal with this mail order crap.
    Step 11endy million: Research. If your on a car forum and havent learned what WOT is...I suggest searching, googling, and lots of reading for you sir.
  13. #13 Re: what exactly is WOT?
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Buying an Intense PCM is like paying someone to punch you in the face.
    For all your 3800 needs:
  14. #14 Re: what exactly is WOT?
    MO
    Quote Originally Posted by copgtp View Post
    that bad huh? guess i should come up with a new plan.
    <brandonl2000> LMAO D!!
  15. #15 Re: what exactly is WOT?
    Quote Originally Posted by ZR1Vette09 View Post
    They're known to toast tranny's and the ZZP's were known to blow motors.
    DHP is the only mail order PCM I would buy.
  16. #16 Re: what exactly is WOT?
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
  17. #17 Re: what exactly is WOT?
    Sterling
    Where can i get a "custom" tune then???
  18. #18 Re: what exactly is WOT?
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    start looking local for shops that have a good rep on the street and see what they have for online reviews and such
    that or post in the forums in your area to find a tuner
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  19. #19 Re: what exactly is WOT?
    Orange County, NY
    I've been around the since the time that DHP and 3800performance PCM's where the only available aftermarket. Intense started doing PCM's and toasted quite a few engines by ramping up the timing tables. Then it was found that their tranny settings weren't agressive, but they just maxed every value out. Hap-hazard tuning practices...
    I know ZZP did have some issues in the past also, but not nearly as much/as bad as Intense.
    DHP is the way to go in this case.
  20. #20 Re: what exactly is WOT?
    Jersey
    my intense pcm had factory trans settings...
    it blew pee-pee hole, 9* of knock, I'm surprised my motor is still alive.
    then i had a reputable shop dyno tune the car...
    $428 later, i went 2 mph slower in the 1/4 and a hole lot of wtf in my file
    now a local member is helping me out...
    He couldn't use anything in my pcm, so he started from a factory gtp file, street tuning to come, we'll see where that takes the car
    16' wrx sti- stock
wot
