Thread: What is a "tune"?
Results 1 to 17 of 17
  1. #1 What is a "tune"?
    SE Level Member Smalltownmodder's Avatar
    Westfield, pa
    So I've heard some people talking about a "tune" or "Tuner". Something you hook up to the PCM. I'm wondering if anyone can give me some info on just what a tuner is and how it works, maybe where to find the best one.
  2. #2 Re: What is a "tune"?
    a tune is modifying the file on the PCM in order to get more power and/or better driveability out of the car.
    a tuner allows you to do this by being able to pull, edit, and push the files. for tuners you really only have two options: HPTuners or DHP Powertuner (which is no longer made and you'll only find it used).
  3. #3 Re: What is a "tune"?
    Westfield, pa
    Thanks, Is it pretty easy to do, or something I need to leave to a pro? I mean I'm pretty DIY and I'd love to but I know I have limits. And what amI looking at price wise?
  4. #4 Re: What is a "tune"?
    Donating Users Warbeaver's Avatar
    St. Louis
    all i can say before you try tuning yourself...RESEARCH RESEARCH RESEARCH
    it can be an involved process.
    price wise, i'd say you're anywhere in between $200-$350 depending on seller
  5. #5 Re: What is a "tune"?
    Westfield, pa
    Thanks for the info it's a lot of help.
  6. #6 Re: What is a "tune"?
    GT Level Member chickenfried's Avatar
    Feb 2010
    Gilman IA
    dont mean to threadjack but my questions goes along with the topic, when should i tune? i have a friend with a tuner and im just curious after which mods i should tune the car, or does it need to be just once?
  7. #7 Re: What is a "tune"?
    Apr 2009
    stockton ca
    pulley drops equal tune time
    meth equals tune time
    n2o equals tune time
    Any major mod you should tune for even a complete stock car should be tuned
  8. #8 Re: What is a "tune"?
    Feb 2010
    Gilman IA
    is there such a thing as tuning to much? i know dumb questions but i have to ask. made a fwi, and hopefully a dp soon, tune after that? new plugs and wires and tstat, tune after that too? and then the 3.4 pulley and tune(i know that much)
  9. #9 Re: What is a "tune"?
    Apr 2009
    stockton ca
    first tune should come with the pulley drop no need to tune for every little change
    i have a basic mail order tune and ill run it even with my 3.2 drop but will dyno tune when i add meth
  10. #10 Re: What is a "tune"?
    Feb 2010
    Gilman IA
    so is it better to get a new pcm period or just have the stock on hooked up to a pc or tuning device?
  11. #11 Re: What is a "tune"?
    Apr 2009
    stockton ca
    depends if you have a compitent tuner if your not modding that far id say get a mail order and your in bussiness
    ALl depends what your looking to do
  12. #12 Re: What is a "tune"?
    Feb 2010
    Gilman IA
    supporting mods and 3.4
  13. #13 Re: What is a "tune"?
    Apr 2009
    stockton ca
    Quote Originally Posted by chickenfried View Post
    just get a dhp,intense or overkill pcm and supporting mods and your good to go
  14. #14 Re: What is a "tune"?
    GT Level Member Robroy04gtpcompG's Avatar
    ca
    i have a short ram intake, a good set of racing wires, what else do i need, or would be recommended to install before doing a 3.4 pulley drop? i just found a guy that can dyno tune my car.
  15. #15 Re: What is a "tune"?
    Apr 2009
    stockton ca
    headers and im not sure about 3.4 you have a genv sc so 3.6 is equal to the 3.4 on a genIII I could be off on that
  16. #16 Re: What is a "tune"?
    ca
    what headers for california? what are you running? i'd like them to be smog legal
    what about PEM?
    i meant to put 3.6, as that is what i am planning.
  17. #17 Re: What is a "tune"?
    Apr 2009
    stockton ca
    Only one smog legal header and its TOG's they are pricey
    i also dont know abot 04+ i know there legal on 97-03
    I ported the crap out of my from mani and am having a dp made with out the dp though i have zero kr But im also cammed so i dont know how much that plays
    Id say PEM's and a dp youl be good to go with a good tune
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
  3. "97" 4t65e-hd succesfully installed replacing the "00" 4t65e-hd
    By mikedinthecity in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-06-2009, 01:42 PM
  4. "Check CD" or "error reading cd"
    By pontiacprincess in forum Audio, Security & Visual Electronics
    Last Post: 04-04-2009, 08:22 PM
