Thread: 100 RPM Fluctuations
Results 1 to 14 of 14
  1. #1 100 RPM Fluctuations
    SE Level Member CSteen85's Avatar
    Long Island, NY
    This might be a totally stupid question, but I'm curious.
    Are frequent fluctuations of about 100 RPMs at idle normal?
    While I'm sitting in park, I noticed that my RPMs are bouncing between 700-800 RPMs the whole time. Meaning, its not holding steady on the gauge.
    The car itself seems to drive fine and I recently replaced a vacuum line and cleaned the MAF sensor.
    Any input is appreciated. Thanks!
    1997 Grand Prix SE, 3.8L V6 SFI, 140k, purchased on 3/6/10.
  2. #2 Re: 100 RPM Fluctuations
    Apr 2009
    stockton ca
    not really normal no
    Id say theres still a vac leak maybe or something else
  3. #3 Re: 100 RPM Fluctuations
  4. #4 Re: 100 RPM Fluctuations
    Jul 2008
    sumter,south carolina
    im sure shes estimating... when i had a vac leak, if u looked hard enough u could see the needle barley dip down and up.
    02 GTP with mods 05 GP for DD
  5. #5 Re: 100 RPM Fluctuations
    okay, i didnt know these cars had a completely rock solid idle.
  6. #6 Re: 100 RPM Fluctuations
    Long Island, NY
    Quote Originally Posted by TorqueAutoMotiv View Post
    Ah, I guess this will be my Saturday morning project. The Vac Leak Hunt.
    Thank you!
  7. #7 Re: 100 RPM Fluctuations
    Apr 2009
    stockton ca
    Not perfectly solid no but if they moved 100 rpm's up or down at idle in cali we would fail smog tests
  8. #8 Re: 100 RPM Fluctuations
    THAT is weak sauce. even so, 100 rpm fluctuation is nothing to be worried about. a vacuum leak of that level is small. you might not even find it.
  9. #9 Re: 100 RPM Fluctuations
    Apr 2009
    stockton ca
    very true
  10. #10 Re: 100 RPM Fluctuations
    Charles City, IA
    Mine has always done that. Dont worry about it.
    SMGPFC Two Nipple General
  11. #11 Re: 100 RPM Fluctuations
    SE Level Member jshifti33's Avatar
    South Bend, IN
    I agree with Bio on this one. A vacuum leak that small is not worth your time trying to find. As long as you don't have a check engine light on I wouldn't worry about it.
  12. #12 Re: 100 RPM Fluctuations
    Long Island, NY
    I'm more or less just worried about not passing inspection this month in NYS.
    I guess I have to just try and see what happens.
  13. #13 Re: 100 RPM Fluctuations
    MO
    just get it in for an inspection early so if you fail you have time to look. 100 rpms is something i wouldn't be too worried about
    <brandonl2000> LMAO D!!
  14. #14 Re: 100 RPM Fluctuations
    SE Level Member almighty's Avatar
    northern illinois
    if all else fails get a wrench and put a slight twist on all the intake bolts, dont crank them just resnug them, sadly this is an issue i had with my l67
  1. voltage fluctuations DIC
    By ghostgt in forum General Tech Discussion
    Last Post: 10-31-2008, 10:15 PM
