Thread: Can't put driver's side window up!
Results 1 to 12 of 12
  1. #1 Can't put driver's side window up!
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    I'm just glad this happened while I was at home. Anyway, I pressed the down button on my window accidently. I pressed it up and it wouldn't go back up. Like an idiot, I decided to send it down lower. Now it's all the way down, and still won't go back up. I took out the window controls switch. I can hear a click when I push the driver's side down, and when I push the passenger side control up and down. Is there any way I can roll it up short term until I can get to a Pontiac parts department, and any idea how much it would cost. Is there a way to manually roll the window up, or am i just gonna have to put a bag over it for now?
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  2. #2 Re: Can't put driver's side window up!
    Banned - Busted For Scamming
    Feb 2009
    can you hear the motor turn?
  3. #3 Re: Can't put driver's side window up!
    TDCRacing
    Guest
    Some times the contacts in the rocker switch get worn out. Taking them apart and cleaning them with contact cleaner should do the trick. If not you may just need to jump it off and get it up or else get a new switch.
    One of the possible causes anyway.
  4. #4 Re: Can't put driver's side window up!
    Feb 2008
    Cumming GA
    It was one of the little white pieces at the bottom of the switch. I figured it was the switch, so I took it apart knowing I'd order a new one. I was able to move the white clear pieces to the drivers side switch and hook it back up enough to roll the window up. So I'll be OK until the new piece shows up hopefully this week. Just glad the A/C is working and I don't have to roll the window down!
  5. #5 Re: Can't put driver's side window up!
    Feb 2009
    yea, been there done that
  6. #6 Re: Can't put driver's side window up!
    Feb 2008
    Cumming GA
    I'm just glad I've never been in the habit of playing window yo-yo, so the motor is still good.
  7. #7 Re: Can't put driver's side window up!
    SE Level Member bigbadfloyd's Avatar
    charles county,md
    Quote Originally Posted by deezul_awt View Post
    i'm just glad i've never been in the habit of playing window yo-yo, so the motor is still good.
    i had same problem the white plastic tip gets worn down to a nub. J ferguson write up with pics showed me the way
  8. #8 Re: Can't put driver's side window up!
    Troy OH
    Quote Originally Posted by bigbadfloyd View Post
    can we get a link here please?
  9. #9 Re: Can't put driver's side window up!
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    I'm still trying to find a new switch, all I can get around here is one from a 4 door. But I went to the harness and put jumper wires on a pushbutton, so I can at least put the window down, and back up! It looks like sh!t but at leas it works until I can get a new switch. And Yes, I have tryed taking it apart, the white pice is broke, and I dont have replacement parts... so I wait.
    98' GTP, 18's, BMR Adjustable Forward & Rear Lateral Arms, BMR Tubular Trailing Arms, Intense PCM, CAI, drilled rotors, 5% Tint all around
  10. #10 Re: Can't put driver's side window up!
    Feb 2008
    Cumming GA
    Quote Originally Posted by 98GTPCALGARY View Post
    I bought a non-OEM version off eBay, and the auto part now doesn't work. Not a big deal as I'm used to it now. But my next trip to the junk yard I'm going to look for a few of them.
  11. #11 Re: Can't put driver's side window up!
    Feb 2009
    Red Deer AB
    Took me a bit, but I found it, Here ya go!
    http://www.grandprixforums.net/window.php
  12. #12 Re: Can't put driver's side window up!
    Troy OH
    man, not what i thought you were talking about, but thanks for the effort!
  1. Trim piece on my driver's side door broken
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 05-15-2010, 11:59 AM
  2. Window Problem (Front Driver Side Window)
    By trogdor007 in forum General Tech Discussion
    Last Post: 06-03-2009, 09:22 PM
  3. Side mirror on driver's side
    By jokyfo in forum Shops and Community Heroes
    Last Post: 04-29-2009, 03:50 PM
  4. Driver's side axle / halfshaft issue...
    By GrandPrixGT300 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-19-2009, 04:00 PM
