Thread: HID Projector Retrofit
Results 1 to 18 of 18
  1. #1 HID Projector Retrofit
    Feb 2008
    Has anyone considered retro-fitting a set of bi-xenon projectors into a stock headlight housing? I think I'm going to give it a try over the next few months. All of the projector housings out on the market seem to use smaller bulbs and render the high beams useless.
    My (and a friend's) idea is to use a set of FX-R projectors from The Retrofit Source and fit them into a spare set of stock-style housings. If I decide to do it, I'll do a full picture step-by-step on the whole project.
  2. #2 Re: HID Projector Retrofit
    May 2008
    staten island,NY
    im already cultivating this caper....should be done in a couple of weeks
  3. #3 Re: HID Projector Retrofit
    Feb 2008
    Got any pictures? I'd like to see how you're doing it. What capsules are you using?
  4. #4 Re: HID Projector Retrofit
    Feb 2008
    Just ordered a pair of FX-R's. Hopefully they will be here by the weekend so I can get started. I will probably end up going with a set of Phillips bulbs, but keep my PNP ballasts with adapters (for now).
  5. #5 Re: HID Projector Retrofit
    Banned - Busted For Scamming
    Feb 2009
    I have started a while ago. Im using caddy projectors. Here is my progress but wont be able to work on them for a while yet cause im booked!!!
  6. #6 Re: HID Projector Retrofit
    Feb 2008
    Looks pretty nice. How are you mounting them?
  7. #7 Re: HID Projector Retrofit
    Feb 2008
    Got all of my stuff in for the retro! I plan to at least have one done enough I can take a picture of it to show off tonight.
  8. #8 Re: HID Projector Retrofit
    Feb 2008
    Got a little bit of work done yesterday. Unfortunately, my camera took a crap on me, so I only have a few I took with my cell phone.
    The project is far from finished. The housing has a huge hole cut out of the bottom and the FX-R is being held in place by a 7mm wrench... I will probably be blacking out the turn signal/corner marker, but leaving the orange reflector in.
  9. #9 Re: HID Projector Retrofit
    Nov 2009
    Grand haven
    HOLLY BUGS MAN!!! Looks like you are making good progress. Keep us updated!!!
  10. #10 Re: HID Projector Retrofit
    SE Level Member Slueth66's Avatar
    Nov 2008
    Iowa
    sick, end of story
  11. #11 Re: HID Projector Retrofit
    Feb 2008
    Slow goings this past week... too much other crap to take care of. It should be finished before the end of the month, however. I have to move out by then...
  12. #12 Re: HID Projector Retrofit
    Feb 2008
    Finally picked the project back up... Got one mounted in the housing and all blacked out. Now I move on to the passenger side. I'm hoping to finish the mounting process tonight so I can get them aligned and painted and possibly finished by this weekend...we'll see
  13. #13 Re: HID Projector Retrofit
    FX-Rs are a bit bulky.
    I just did some work with the morimoto mini's and you know what, they are so small and easy to work with.
    Good work so far, looks like your taking all the right steps to doing a proper retrofit.
  14. #14 Re: HID Projector Retrofit
    Nov 2008
    Iowa
    mines done, i should probably post pics someday
  15. #15 Re: HID Projector Retrofit
    GT Level Member josemolina2008's Avatar
    Modesto, Ca.
    I wanna do this also, I'll be checking back in for more progress and more details on a how to.
    GP is gone...
  16. #16 Re: HID Projector Retrofit
    Feb 2008
    If the new morimotos were available when I started this project, I would have gone that route. I'll get some more pictures of my project for you all.
  17. #17 Re: HID Projector Retrofit
    Yeah I said the samething after I did the second Retro.
    I used the Fx-R's the first time round.
  18. #18 Re: HID Projector Retrofit
    GT Level Member Tommyp2010's Avatar
    Poland, Ohio
    I know this is an old thread, but did you ever finish this project? I'd like more details, as I'd MUCH rather run the fx-r than the mini h1, there's no real comparison in output. The mini just doesn't do it for me, and I wanna run oem bulbs + ballasts. I'd like to see some pics of how you mounted it + sealed up the back. I was thinking about cutting out the back of the light, inserting the projector from the rear, and using jb weld to hold it in, which I've seen done successfully on other cars in the past.
    2006 Mitsubishi Evo IX MR
  1. I need projector help
    By rocafella2032 in forum Visual/Body Modifications
    Last Post: 04-30-2011, 07:47 AM
  2. Projector HID
    By rocafella2032 in forum General Tech Discussion
    Last Post: 04-29-2011, 11:15 AM
  3. Projector retrofit for 9006 04+ from 3B?
    By Ashman in forum Visual/Body Modifications
    Last Post: 01-03-2010, 12:11 AM
  4. Projector retrofit for 9006 04+ from 3B?
    Last Post: 01-02-2010, 11:02 PM
