Thread: recall info?
Results 1 to 11 of 11
02gtpsleeper recall info? 11-16-2009, 02:49 PM
toolguy Re: recall info? 11-16-2009, 02:52 PM
97gtsc Re: recall info? 11-16-2009, 02:54 PM
02gtpsleeper Re: recall info? 11-16-2009, 03:08 PM
toolguy Re: recall info? 11-16-2009, 03:33 PM
BoostJunki3 Re: recall info? 11-16-2009, 03:26 PM
toolguy Re: recall info? 11-16-2009, 03:35 PM
matt5112 Re: recall info? 11-16-2009, 04:23 PM
02gtpsleeper Re: recall info? 11-16-2009, 05:35 PM
Joe m Re: recall info? 11-17-2009, 02:20 PM
matt5112 Re: recall info? 11-17-2009, 02:23 PM
  1. #1 recall info?
    GT Level Member 02gtpsleeper's Avatar
    Hanover Park, Illinois
    I just got a letter in the mail for my 2002 gtp stating i havnt had work done for a recall: 7035 Engine Compartment Fire. wondering if anyone know any info on this matter
  2. #2 Re: recall info?
    Guam
    Take it seriously! There have been many fires due to this issue. The recall has to do with the spark plug retainers. The old retianers can hold oil, until it pools and then it dumps onto the header and ignites. It can happen many minutes after the engine is shut off too.
  3. #3 Re: recall info?
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    x2^^
  4. #4 Re: recall info?
    even with a heavily mod'ed car this can be the issue... i purchased to car in june.
    two things
    1. mods would change this?
    2. them replacing or fixing this issue wouldnt mess with anything ?
  5. #5 Re: recall info?
    Guam
    Quote Originally Posted by 02gtpsleeper View Post
    two things
    Honestly, it was done to my car before I bought it at 130K miles and if you have re-routed your plug wires with new retainers, you may be fine. Is this what you mean?
    If so, DO NOT quote me on this, as I am not an expert.
    No, the new retainers would not mess, or change aything for your mods.
  6. #6 Re: recall info?
    Joliet, IL
    is this the rear valve cover leaking into the retainers? i have oil on plug #2 alot guess i should take in....
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  7. #7 Re: recall info?
    Guam
    Quote Originally Posted by BoostJunki3 View Post
    Accoridng to the recall, yes... Once the recall is fixed, I am sure the dealer would want to do the cover gasket next at your expense though, if it is bad.
    1997-2003 Buick Regal and Pontiac Grand Prix vehicles equipped with a 3.8L supercharged V-6 engine. Engine oil can leak from the valve cover and can migrate during maneuvers such as hard braking. If the oil reaches the hot exhaust manifold, it may ignite causing an underhood fire. Until sufficient parts become available to repair all of the affected vehicles, GM strongly recommends that owners observe the following important precautions: (1) they strongly recommend that owners do not park their vehicle in a garage, car port, or other structure; (2) if owners notice a burning odor, they should have their dealer inspect the vehicle. The dealer will inspect the vehicle without charge; (3) use premium fuel (91 octane or higher) in the vehicle as recommended in the vehicle's owner manual. Owners may contact Buick at 1-866-608-8080 or Pontiac at 1-800-620-7668. This recall was the subject of an Engineering Analysis, EA07-008, conducted by the Office of Defects Investigation. 08V118
  8. #8 Re: recall info?
    Picked up some perma-dry gaskets today...
  9. #9 Re: recall info?
    alright so i'll call to have them check this out. all gaskets have been replaced except on the oil pan.
  10. #10 Re: recall info?
    GT Level Member Joe m's Avatar
    mesa,az
    toolguy wrong. gm dealers actually have the front valve cover gasket setup as part of the recall repair on the engine fire. i just took my 99 gtp last week to have the retainers and the front vc done for free.
  11. #11 Re: recall info?
    Quote Originally Posted by Joe m View Post
    X2, called my local dealership to check if my car had been serviced. In May apparently.
    Theres also a coolant leak recall out that will have the throttle body resealed if it was explained to me correctly.
  1. Top Swap Info and Faqs, Also lots of 3800 Info
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2024, 11:56 PM
  2. Recall
    By SlowM90 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-15-2009, 07:11 PM
  3. Recall!?!?
    By FtBll Coach in forum The Rant Forum
    Last Post: 05-23-2009, 06:09 PM
  4. Gm recall
    By boostjunky in forum General Tech Discussion
    Last Post: 04-16-2009, 11:04 AM
  5. ? on recall
    By mlambert in forum Off Topic Discussion
    Last Post: 06-20-2008, 02:58 PM
