Thread: how to install a oil pressure sender
Results 1 to 11 of 11
  1. #1 how to install a oil pressure sender
    GT Level Member Will5600's Avatar
    subs of chicago
    i was looking into getting a oil pressure gauge and wasnt sure how i would install it Prosport Gauges Oil Pressure Gauge 52mmthis is the one i was looking at
    Signature deleted for being TOO BIG. Resize your picture and try again.
    - Management
  2. #2 Re: how to install a oil pressure sender
    you have to run a wire from the oil pressure sending unit, that screws into the oil pump housing near the passenger rear of the engine bay under the car, and back into the cabin for the gauge. the sending unit can either take the place of the low oil pressure sensor or you can use a brass T to use both.
  3. #3 Re: how to install a oil pressure sender
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    why would you keep the old one in there it only goes to a dummy light
  4. #4 Re: how to install a oil pressure sender
    some people like to do that so its still complete like it should be. i never cared and mine just hung there zip tied up.
  5. #5 Re: how to install a oil pressure sender
    subs of chicago
    will that sending unit just screw righ in place of the oil level sensor and then if it does will the light go on
    - Management
  6. #6 Re: how to install a oil pressure sender
    its not for the oil level sensor, its for the oil pressure sensor. it will screw right in so long as you bought the right thread size for it. the oil pressure light will not come on unless you put a T fitting on it so you can still use both. however, the oil pressure light comes on at like 5 psi, which is too late anyway.
  7. #7 Re: how to install a oil pressure sender
    Jul 2008
    sumter,south carolina
    soooo true my low pressure light came on as a rod shot through my oil pan today.
    02 GTP with mods 05 GP for DD
  8. #8 Re: how to install a oil pressure sender
    subs of chicago
    dose anyone know the thread size then for where the oil level sensor goes
    - Management
  9. #9 Re: how to install a oil pressure sender
    Charles City, IA
    Most come with a couple different sizes. My auto meter came with the right one.
    SMGPFC Two Nipple General
  10. #10 Re: how to install a oil pressure sender
    SE Level Member $03gp/gt$'s Avatar
    Feb 2008
    Chillicothe/Peoria IL
    got any pics of how this is done?
  11. #11 Re: how to install a oil pressure sender
    subs of chicago
    do u want to see where it goes
    - Management
  1. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  2. Hooked up a Fuel Pressure Sender (with pics)
    By BlackGS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2008, 09:28 PM
  3. Tranny Sender Type?
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-23-2008, 08:32 AM
  4. Temperature sender location
    By bat119 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-25-2008, 09:23 AM
  5. Oil Level Sender Thread
    By Speeder in forum Turbo
    Last Post: 01-08-2008, 09:25 PM
