Thread: Fuel Pump o-ring replacement
Results 1 to 4 of 4
  1. #1 Fuel Pump o-ring replacement
    Pa
    Could someone tell me how difficult it is to seat the o-ring properly. I am currently getting a code p0440 and i found last night that i am getting air bubbles around the locking ring after lightly spraying water around it, not the best way but all i could think of. Also how do you change the orings at the fuel rail connection, loud hissing noise. I am hoping that this will solve my evap problem. Any suggestions are greately appreciated
  2. #2 Re: Fuel Pump o-ring replacement
    Charles City, IA
    Pull the fuel pump, make sure the slot for the oring is clean and put it in. You need a quick connect tool to disconnect the fuel lines.
    SMGPFC Two Nipple General
  3. #3 Re: Fuel Pump o-ring replacement
    Pa
    Do u think that this could be good cause of the code. When i connect the scanner i says the test was aborted due to weak vacuum. I have tried removing the fuel cap while the engine is running watching the fuel pressure sensor for changes but nothing happens weather the cap is on or off. I am also getting a loud hissing noise at the fuel rail connection
  4. #4 Re: Fuel Pump o-ring replacement
    GT Level Member GreyGhost's Avatar
    Nov 2009
    IL
    Have you tried replacing the fuel cap? THat is a commom problem when this code comes up that the fuel cap wasn't reinstalled properly or is failing.
  1. Power Steering Pump Replacement [*]
    By UR LOSN in forum How To Write-Ups/Tech Tips
    Last Post: 05-11-2013, 03:28 PM
  2. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
  3. Fuel Injector O-ring ????
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-24-2008, 05:16 PM
