Re: Fixing One Problem Created Another...
it sounds like there is still a slight leak somewhere. get to it with the carb spray.
Bio248
Will do, Bio! Can I use WD-40? Or is Carb spray my only option?
wd-40 doesnt help a ton in that situation. youll end up using the whole can.
youre almost best off using starting fluid.
CSteen85
carb spray ,brake klean, chem tool will all work
Okay guys, I'm pretty sure this problem is fixed!!
When I let the engine warm up all the way, she runs beautifully. It's like a new car. No idling problems or anything anymore.
I'm very excited. Thank you all for your help! You've done a wonderful job.
:th_clapping:
Re: **FIXED!** Fixing One Problem Created Another...
next you can take on changing spark plugs and a trans pan drop and filter change :-)
TorqueAutoMotiv
That is next on my list of things to learn!! I'll need to first learn how to figure out how to tell when they need to be done. I'm pretty sure the guy I bought it from said it was recently tuned-up, so I might have a little while. We'll see!
