Thread: Antifreeze Pooring Out Of 2001 GP 3.8
Results 1 to 3 of 3
  1. #1 Antifreeze Pooring Out Of 2001 GP 3.8
    Iowa
    I can't see exactly where this is coming from. It appears to be dripping down onto the rim of the oil pan on the drivers side then on down. At first glance it would look like it is coming out of the pan itself but the quickly you can tell that it is dripping from above it.
    Anyone have any ideas what is right above the that area of the pan that would have antifeeze flowing through or flowing over it? Is there a sending unit down there? By-Pass hose of some sort?
    Thanks.
  2. #2 Re: Antifreeze Pooring Out Of 2001 GP 3.8
    Fort Atkinson
    Gp up top and look. Could be head gaskets, intake gaskets, anything. Gots to look to find it. Maybe you'll be lucky and its just the t-stat housing seal, mine was bad after a recent rebuild and it leaked badly after warmup.
  3. #3 Re: Antifreeze Pooring Out Of 2001 GP 3.8
    SE Level Member GTPcoupe's Avatar
    Feb 2010
    Canada
    It's often a gasket on the top end that has gone bad. Have a good look at these areas...
    1) front and rear of the engine just above the valve covers around the fuel inectors (when intake gaskets go bad, coolant usually pools there)
    2) Look at the bottom of the throttle body for coolant leaks (there is a small passage for coolant at the bottom of the stock throttle body)
    3) look at thermostat housing for any signs of leaks
    4) Check all the coolant hoses. Don't forget the 2 hoses at the back that lead to the firewall.
    Good luck.
    '99 GTP coupe - Growing mod list/summer car
    '98 GTP Sedan - Winter ride, 315,000+kms and going strong!
  1. Antifreeze Pooring Out Of 2001 GP 3.8
    By MDThomas26 in forum General Tech Discussion
    Last Post: 04-10-2010, 09:25 AM
  2. antifreeze leak..
    By bowtechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:36 PM
  3. Antifreeze leak...
    By bowtechguy in forum General Tech Discussion
    Last Post: 03-23-2009, 07:24 AM
  4. Smelling antifreeze
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2008, 11:06 PM
  5. Leaking Antifreeze
    By GTPluv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 08:13 PM
