Thread: port plans
Results 1 to 15 of 15
  1. #1 port plans
    Joliet, IL
    here is my port line that im about to port in an hour any comments suggestions all internal holes/needle bearing masked off....
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: port plans
    Banned - Busted For Scamming
    Feb 2009
    Yea that looks good. I usually dont actually open up the outlet just take out the bolt bosses and smooth it out.
    Like this:
  3. #3 Re: port plans
    Joliet, IL
    here is my end result pretty good for a dremel cutter and a flapper wheel
    should i bother smoothing the bottom of the outlet out or no?
    00 Silvermist GTP
  4. #4 Re: port plans
    Joliet, IL
    i think i might fill the silencers too just for the hell of it....
    00 Silvermist GTP
  5. #5 Re: port plans
  6. #6 Re: port plans
    GT Level Member rolyat's Avatar
    OKC
    ^^Why wouldn't he? It just helps lower outlet temps a little more
  7. #7 Re: port plans
    Quote Originally Posted by rolyat View Post
    ...youre not supposed to open up the triangle, just extend it...
  8. #8 Re: port plans
    in a house
    This has been tested many times and just smoothing out the outlet is the way to go.
  9. #9 Re: port plans
    OKC
    hmm... learn something new everyday.
    I think he'll be fine though, he didn't open it up stupid big.
  10. #10 Re: port plans
    Joliet, IL
    i took off like 2 mm... nothing huge it looks exactly like zzps....i dont think im gonna have any issues with it....
    00 Silvermist GTP
  11. #11 Re: port plans
    Feb 2009
    I just checked their website, since when did their blower porting go up to $400 for outlet only? LOL
    Edit:
    I just saw that you get a brand new rotor pack. Lol, what if you dont want that?
  12. #12 Re: port plans
    GT Level Member TeeWX's Avatar
    Apr 2009
    Cresco, Iowa
    Edit:
    Do the rotors even wear? It seems like they just want to sell you more stuff. I would think you would want the same rotors that came with your case considering your not even suppose to clean them off.
  13. #13 Re: port plans
    Apr 2009
    stockton ca
    they wear and get burs and stuff my old blower rotors are in bad shape
  14. #14 Re: port plans
    Joliet, IL
    Quote Originally Posted by TorqueAutoMotiv View Post
    me too
    00 Silvermist GTP
  15. #15 Re: port plans
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    The bearings in the rotor pack are what wear out, and sometimes the bearing surface on the rear of the rotors where they ride on the needle bearings. The front bearings are swedged in place ( The metal is pressed around them) and when you remove them to replace, you lose metal.
    1997 Pontiac Grand Prix GTP
    1969 Pontiac GTO
  1. Making a L67 RWD...My S10 swap plans
    By Pittman06 in forum Off Topic Discussion
    Last Post: 12-19-2009, 11:38 PM
  2. MY PLANS for the GT
    By offroadfury6 in forum Off Topic Discussion
    Last Post: 10-28-2009, 11:47 AM
  3. Some new plans for the car.
    By 2000GTP in forum Off Topic Discussion
    Last Post: 10-22-2009, 12:03 AM
  4. change of plans
    By IrishNation24 in forum General Tech Discussion
    Last Post: 09-29-2009, 08:34 PM
  5. Future Plans For My GT
    By biggmman in forum General Tech Discussion
    Last Post: 09-30-2008, 04:57 PM
