Thread: BBV solenoid wiring - L67 swappers please help
Results 1 to 7 of 7
  1. #1 BBV solenoid wiring - L67 swappers please help
    SE Level Member WillOverkill's Avatar
    Feb 2008
    I have a customer that put an L67 in his 99 GT. While doing some tuning for him on Monday, I provided him with a wiring harness I fabbed up to connect up his boost bypass valve solenoid, which is required for some of the controls in my newest PCM tunes. It didn't work, and he's stuck at 4psi. He does have a proper L67 tune.
    I ran the grey wire to pin 77 in the PCM, but the other wire I connected to ground and am wondering if it should have been connected to a 12volt source?
    I don't have any GM wiring diagrams and Alldata doesn't show me the BBV connector view.
    Any help is greatly appreciated!
    Get Your 3800 Overkilled @ http://www.getoverkilled.ca
  2. #2 Re: BBV solenoid wiring - L67 swappers please help
    Will, have u tried contacting anyone over hp tuners or dhp forums?
  3. #3 Re: BBV solenoid wiring - L67 swappers please help
    Barksdale AFB, LA
    This help? I assumed a 1999 L67 was used and brought up the connector information for a 1999 GTP. I'm not sure if there were any year differences without going through year by year.
    Looks like the other wire was supposed to be a 12V source. PCM probably provides the ground.
    Edit: Found this. Looks like we were right that the 12V source is applied through the connector from the fuse box, and the PCM pin 77 provides the ground.
    2009 Subaru Impreza WRX STI
  4. #4 Re: BBV solenoid wiring - L67 swappers please help
    Feb 2008
    Excellent, thank you very much!
  5. #5 Re: BBV solenoid wiring - L67 swappers please help
    Bastard Reptile's Avatar
    Kansas City, MO
    Might have to use a 99 GTP PCM.....DeanGTP had this issue, and it turned out he had a GT PCM with the improper OS. Put in a known GTP PCM and the problem was fixed.
  6. #6 Re: BBV solenoid wiring - L67 swappers please help
    TDCRacing
    Guest
    Quote Originally Posted by Reptile View Post
    I knew this thread sounded fimiliar when he said he was stuck at 4 psi...glad you were able to remember
  7. #7 Re: BBV solenoid wiring - L67 swappers please help
    Feb 2008
    The customer switched the wiring and got it fixed, thanks guys!
  1. Key Removal Solenoid
    By thermanlee in forum General Tech Discussion
    Last Post: 08-12-2012, 01:40 PM
  2. Any wiring gurus
    By archemedes in forum Audio, Security & Visual Electronics
    Last Post: 03-20-2008, 06:00 PM
  3. locating wiring
    By Toasty in forum General Tech Discussion
    Last Post: 01-21-2008, 04:39 PM
  4. wiring connector pins
    Last Post: 01-20-2008, 01:12 AM
  5. 2004+ wiring diagrams
    Last Post: 01-14-2008, 01:15 PM
