Thread: 95 GP Shudder at High Speeds
Results 1 to 8 of 8
  1. #1 95 GP Shudder at High Speeds
    North Carolina
    Have a 95 GP with a 3.1L, runs fine cruising around town, on the interstate (60+ MPH) at constant throttle it will shake. The shaking stops as soon as I let off the throttle, almost have to slowly pump the gas to keep it at 70. Replaced the throttle position sensor and does the same thing. Any ideas on what it might be? Plugs/Wires/Transmission? Car has 183k on it and don't know anything of the service history besides what I've done. Thanks!
  2. #2 Re: 95 GP Shudder at High Speeds
    SE Level Member paulygp09's Avatar
    Minnesota
    have you checked the compression lately? i had a buick regal that did this and it was because of bad compression on one side of the motor
  3. #3 Re: 95 GP Shudder at High Speeds
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    try plugs and wires
  4. #4 Re: 95 GP Shudder at High Speeds
    North Carolina
    I haven't checked compression, but I'll do that when I do plugs and wires.
  5. #5 Re: 95 GP Shudder at High Speeds
    HUDSON
    Have you checked the axle shafts? That would be my first place to look.
    Or maybe the TCC is slipping.
    dean
  6. #6 Re: 95 GP Shudder at High Speeds
    North Carolina
    Well it wasn't plugs and wires and the compression was even across all the cylinders. What am I looking for when inspecting the axle shafts? Thanks!
  7. #7 Re: 95 GP Shudder at High Speeds
    Minnesota
    ill give you a bump
  8. #8 Re: 95 GP Shudder at High Speeds
    North Carolina
    Thanks man. It still does the shudder thing, thinking it might be transmission related? I took out the TCC fuse and drove it down a short stretch of interstate by my house and it didn't seem to do it, turned quiet a few more RPMs but it didn't shake, has anyone dealt with the TCC solenoid? How tough is that one to change?
  1. Boost lost at high speeds. Help?
    By pizzi22 in forum General Tech Discussion
    Last Post: 11-06-2009, 11:28 AM
  2. 94 3.1 shudder
    By stevirebel in forum Introductions/Noob Questions
    Last Post: 11-02-2009, 03:12 PM
  3. tranny shudder
    By bpm4x4 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2009, 10:35 PM
  4. Faint Shudder On 1-2 Shift...
    By harrydunn in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-14-2009, 10:53 PM
  5. weird! Shudder on take-off after R or N
    By bigjim in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-07-2008, 06:57 PM
