Thread: fwi vs. ram air
Results 1 to 20 of 27
  1. #1 fwi vs. ram air
    GT Level Member mezzoni's Avatar
    Nov 2009
    Milford, CT
    now i know that a fwi would provide more power because of the colder air, but exactly how much of a difference is there? 7" cone, 4" pvc, no other mods and n/a if any of that matters. plus would there be any difference in the sound it provides? im thinking no, but why not double check...
    2006 pontiac G6 GT coupe - the daily
    2001 pontiac trans am WS6 - pacesetter headers, slp exhaust, diablo sport tuner, ported throttle body, ported MAF, SLP intake lid, B&M shifter, UMI panhard bar, lowered on koni's
  2. #2 Re: fwi vs. ram air
    Willoughby, Ohio
    FWI=colder air combusts the best and gives you more power but consumes more fuel and is more restrictive due to longer pipe
    short ram=better flow and better gas mileage but hot air doesnt give you power like cold air will
    ram air=GTX hood or drivers side headlight taken out (do 1 of the above for better performance)
    i have a N/A GT and i felt a little difference and i got a 4'' tube and 7'' filter, if i baby it i get better mileage too
  3. #3 Re: fwi vs. ram air
    Topeka, KS
    My open cone intake makes the blower scream like a beeetch! I just put the filter on the end of the tb. Get's better gas mileage too. Honestly though, when do you need a FWI other than when your racing?, and how often do you do that legally a year anyways. Me maybe 2-4 times a year.
  4. #4 Re: fwi vs. ram air
    Willoughby, Ohio
    yea the stock air box acts as a silencer so the open cone/short ram will sound louder
  5. #5 Re: fwi vs. ram air
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    its a gt. you will hear it "gulp" when you stomp on it. but you wont get the " scream " that a supercharger has...
    98' GTP, 18's, BMR Adjustable Forward & Rear Lateral Arms, BMR Tubular Trailing Arms, Intense PCM, CAI, drilled rotors, 5% Tint all around
  6. #6 Re: fwi vs. ram air
    GT Level Member mvp2765's Avatar
    Chicago
    i have a k&n short ram...works fine
    00 Black GTP Coupe - SOLD
    04 Black 350Z touring -currently modding
  7. #7 Re: fwi vs. ram air
    Joliet, IL
    SRI/Open Cone FTW.....only thing you suffer from is heatsoak but an lq4 maf will fix that.
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  8. #8 Re: fwi vs. ram air
    Quote Originally Posted by BoostJunki3 View Post
    3 things...
    1) ALL open cone setups at one point or another are going to suffer from heat soak
    2) HOW is the LQ4 going to fix that?
    3) WHY would he run an LQ4 MAF on an N/A car with no other mods?
  9. #9 Re: fwi vs. ram air
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    what would be better (for my setup..... )
    a 3" FWI (no 4" bends to be found anywhere to make a 4" FWI)
    or a 4" short ram?
    It's my DD and I care about fuel economy more than power as I drive 100 miles every day. (most of it is highway driving at 75 MPH....love Colorado speed limits )
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  10. #10 Re: fwi vs. ram air
    Topeka, KS
    Go Short Ram or Open Cone if you care a bout Fuel Econ.
  11. #11 Re: fwi vs. ram air
    Tyler, TX
    when building it is there a preferred spot? Here are two examples, one is down near the fenderwell opening and the second is almost right on the TB.
    THANKS!!!
  12. #12 Re: fwi vs. ram air
    Numero dos senor
  13. #13 Re: fwi vs. ram air
    Tyler, TX
    Thanks blue... so just throw that thing on the TB and go eh?... no piping or anything?.. despite not having an intercooler or meth?
    I'm so glad that I order food at fast food restaurants... otherwise I wouldn't be able to understand what your response was.
  14. #14 Re: fwi vs. ram air
    Quote Originally Posted by 03GTPLE View Post
    Depends...you can always try it and if it doesn't work for you...just run a FWI again
  15. #15 Re: fwi vs. ram air
    Tyler, TX
    ugh... I need a scanner to really be able to tell... oh well, good thing I keep fuel economy reports when I fill up.
  16. #16 Re: fwi vs. ram air
    Tyler, TX
    Numero dos senor
    ...realized the pics and the words didn't match up. Therefore stating "number two" could reference either one.
    I was assuming you were referring to the second pic, not second description (which has been edited and changed now in order to provide a conclusive response).
    I'd prefer not to mess with the intake too many more times.
    THANKS! (again)
  17. #17 Re: fwi vs. ram air
    Second picture...the one with the green.
  18. #18 Re: fwi vs. ram air
    Largo, Florida, United States
    i got a WIZAIR Cold air intake and a SD Ram Air Hood.
    when i race i take the Top off the Cold Air intake because the wind tunnel goes right to the Air Filter
    Might construct a Lid with a hole here in the near future.
  19. #19 Re: fwi vs. ram air
    Donating Users blowfishRus6's Avatar
    g.a.
    try both out, see which one you like the best. its not hard swap them around.
    ive tried NUMERIOUS different set ups, there was pros and cons with all of them. what someone may like about a set up, you may not care for it.
    i would say try both out yourself and see what you like.
    i would also unhook the battery for 20 mins to reset your fuel trims, a large change in intake set up can throw off readings, so i would reset fuel trims to get the most out of it.
    i would say rock each set up for about a week to get a good comparision.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  20. #20 Re: fwi vs. ram air
    Feb 2009
    Red Deer AB
    or a 4" short ram?
    You dont need a 4" elbow, you can use a 3" to 4" reducer on the tb, and then use a solid 45* - 4" elbow, I just built mine on the weekend, but I am waiting for a cone filter with a 4" opening, the one I had was only 3" so I ordered a 4" off ebay
air, fwi, ram
