Thread: Releasing fuel pressure on 97 GT
Results 1 to 5 of 5
  1. #1 Releasing fuel pressure on 97 GT
    SE Level Member Hockeytown19's Avatar
    Cadillac, MI
    How do you release fuel pressure on a 97 GT? I'm about to do a LIM gasket and read i need to depressurize the fuel rail.
    Any help would be greatly appreciated!
  2. #2 Re: Releasing fuel pressure on 97 GT
    Charles City, IA
    You dont need to. Leave the rail connected to fuel lines unbolt it and move it over to where the air box sat.
    SMGPFC Two Nipple General
  3. #3 Re: Releasing fuel pressure on 97 GT
    Or if you want to pull your fuel pump fuse then start your car.
    After it dies, try to start it for another 3 seconds then stop. Should be depressurized.
  4. #4 Re: Releasing fuel pressure on 97 GT
    GTP Level Member Scimmia's Avatar
    QCA, IA
    I prefer to just press the schroeder valve on the front of the fuel rail. Wrap a rag around it and press it with a screwdriver.
    As 01GTP said, though, you really don't need to for a LIM job.
    2001 Buick Regal LS - Almost Stock
  5. #5 Re: Releasing fuel pressure on 97 GT
    Charles City, IA
    Or I just hold a rag under the fuel line when I disconnect it and leave it pressurized.
  1. which fuel pressure regulator to buy?
    By DOUGLASMELTER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2009, 05:09 PM
  2. '98 SE L36, no fuel pressure while cranking
    By 98SEGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-13-2009, 01:56 AM
  3. WOT fuel pressure
    By Sabrewings in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-05-2009, 12:38 AM
  4. Fuel Pressure
    By RedGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2008, 10:53 PM
  5. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
