Thread: How difficult? - valve covers
Results 1 to 10 of 10
  1. #1 How difficult? - valve covers
    SE Level Member pontiacgp759's Avatar
    Feb 2009
    Ada, OH
    I'm leaking a fair amount of oil from my front and rear valve cover gaskets. I'm going to go ahead and change them this weekend. Has anyone had any experience changing them? how difficult/how long will it take me? Is there anything I should know? Thanks
  2. #2 Re: How difficult? - valve covers
    GTP Level Member
    Nov 2008
    MA
    make sure to scrape all the old gasket away to leave you with a fresh clean surface..rock the motor forward and have it stay there to access the rear easier..so easy a blind person can do it
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  3. #3 Re: How difficult? - valve covers
    scrape gasket? Its a rubber gasket. It should just pull off in one piece.
  4. #4 Re: How difficult? - valve covers
    West Side Michigan
    I think he meant the flat surface. The only problem I ran into when replacing my Valve Cover Gaskets was taking of the bracket that's connected to the coil packs. There was a bolt that was very hard to loosen since I couldn't get a socket to it. You have use a wrench and have very little room to work with...
  5. #5 Re: How difficult? - valve covers
    Clean it up with a towel.
    Note, inside lip of that mating surface is sharp, can cut too.
  6. #6 Re: How difficult? - valve covers
    Apr 2009
    stockton ca
    You can get to the coil bracket bolt with a spark plug socket that has the hex on the back then use another socket on the sparkplug socket
    Other wise its a peice of cake couple hours max if you take your time
  7. #7 Re: How difficult? - valve covers
    Charles City, IA
    Quote Originally Posted by TorqueAutoMotiv View Post
    never thought of doing that.
    SMGPFC Two Nipple General
  8. #8 Re: How difficult? - valve covers
    Apr 2009
    stockton ca
    Im good at coming up with random ways at doing simple jobs it works good great though
  9. #9 Re: How difficult? - valve covers
    Donating Users mystic231's Avatar
    Michigan
    It's covered under a recall. My '02 GTP was done by a dealer and a have a postcard laying here from GM to get my '98 GT done.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  10. #10 Re: How difficult? - valve covers
    Donating Users Warbeaver's Avatar
    St. Louis
    its pretty simple. just some stuff you gotta take off. on a gtp, you take off the alternator, maybe the map bracket, the coil pack bracket, and the dog bones. Beneath the alternator is a bracket that has 3 bolts. You need to take those 3 bolts out. This will enable you to move it a little to slide the valve cover out. You can't move it too far though because the coolant elbow is connected to it. This is how i did mine. I didnt feel like draining coolant and putting on a new elbow just for valve cover gaskets.
    Ideally, its better to do valve covers when you do Intake manifold gaskets, cuz everything will be off anyways, and the coolant will already be drained, and you will need new coolant elbows.
    If you aren't doing gaskets, just do as said. I have done it twice to install rockers with no problems. And, yes, take a utility blade and scrape the surface of the head where the valve covers go on.
  1. Smooth Valve Covers
    By stlmo_gtp in forum How To Write-Ups/Tech Tips
    Last Post: 01-19-2012, 02:03 PM
  2. 3800 Valve covers
    By Sonny in forum Shops and Community Heroes
    Last Post: 12-09-2009, 07:10 PM
  3. zzp valve covers
    By rodman in forum Turbo
    Last Post: 08-30-2009, 04:20 PM
