Thread: couple critical questions
Results 1 to 6 of 6
TheGreatSamG couple critical questions 03-25-2010, 02:11 AM
TheGreatSamG Re: couple critical questions 03-25-2010, 02:13 AM
TheGreatSamG Re: couple critical questions 03-25-2010, 02:14 AM
Bio248 Re: couple critical questions 03-25-2010, 07:51 AM
alkygto Re: couple critical questions 03-25-2010, 08:15 AM
TheGreatSamG Re: couple critical questions 03-25-2010, 08:51 AM
  1. #1 couple critical questions
    SE Level Member TheGreatSamG's Avatar
    Oct 2008
    chicago
    I need some help on a few things on my 98 GTP.
    FIRST I have to change the fuel injectors because it is misfiring. The problem is I don't know which ones to buy because I'm slowly Modding my car.
    Right now I got the custom fender wall air intake. Soon ill be getting a downpipe with the magnaflow catback from zzp and deciding on either pacesetter exhausted or flowmaster 40 series.
    Also is there a way to change the crankshaft position sensor without taking the pulleys off. The plastic peiece is a pain trying to get it off. Hopefully when I change this sensor my rpms will stop randomly turning off on me.
    I have no idea why my ABS/tcs lights are on
  2. #2 Re: couple critical questions
    Oct 2008
    chicago
    And hopefully by the end of the year ill be putting in a 3.4 pulley.
    Pcm?? I dunno when I should get that. I don't want to keep re tuning it
  3. #3 Re: couple critical questions
    Oct 2008
    chicago
  4. #4 Re: couple critical questions
    Quote Originally Posted by TheGreatSamG View Post
    first, why is your first guess for a misfire the injectors? usually those are the LAST thing you guess at when youre misfiring.
    both of those exhausts will sound like poop, but okay.
    no there is no way to change the CPS without taking off the crank pulley unless youre a damn magician.
    your ABS/TCS lights are on at the same time because you need a new wheel bearing.
    if your plans are to continue modding then you will have to continue retuning it. there is no off the shelf pcm that will cover all setups, or any setups really.
  5. #5 Re: couple critical questions
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    Have your injectors cleaned and flow tested. If you can't find anyone local, Stiegemeier Porting Service can do it for $85, cheaper than new injectors.
    Also, I had TCS/ABS light and I had replaced my hub assy's only one year before. Turned out to be a broken wire in the harness a real head scratcher for sure. Good luck.
    1997 Pontiac Grand Prix GTP
    1969 Pontiac GTO
  6. #6 Re: couple critical questions
    Oct 2008
    chicago
    I guess its the injectors because it threw a code and autozone told me. There is new spark plugs and wires. For some reason it doesn't misfire all the time. Its randomly. It can be running fine an if I turn it off for a second and turn it on it can start misfiring. I guess ill have to change the back ball bearings since the front ones are new since last year.
  1. couple of questions
    By selliott in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2010, 12:53 PM
  2. couple of questions, couple of issues
    By zero in forum General Tech Discussion
    Last Post: 12-30-2009, 04:48 PM
  3. A couple of questions.
    By Enjoijoe in forum General Tech Discussion
    Last Post: 04-12-2009, 07:56 PM
  4. I have a couple of questions.
    Last Post: 03-12-2009, 07:07 PM
  5. I Have a couple questions.
    By thenervemann in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2008, 08:07 PM
