Thread: about to order HID's...
Results 1 to 20 of 21
  1. #1 about to order HID's...
    Joliet, IL
    should i get 35w or 55w? im going with 6000k...just dont know which wattage to get....
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: about to order HID's...
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    The 35's will be more than plenty... I ordered mine thru SharpHid. Also with the 35's you should be able to just go plug and play and not need the relay harness. If you go 55, the harness is definately needed... And that is from 3bracing...
  3. #3 Re: about to order HID's...
    Dec 2008
    Lawndale, CA
    The 35W HIDs would be good enough. I have them in my projectors and they are much better then halogens. I recommend you get a relay harness with either kit. I am using a 9007 bi-xenon relay harness from 3bspec for my projectors.
  4. #4 Re: about to order HID's...
    Joliet, IL
    Quote Originally Posted by The Guz View Post
    how much more light do you get with hids in the porjectors? is it insanely diff?
    00 Silvermist GTP
  5. #5 Re: about to order HID's...
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by BoostJunki3 View Post
    Its night and day compared to the silverstars I was using before.
  6. #6 Re: about to order HID's...
    SE Level Member corsagtp's Avatar
    Calgary, AB
    Where did you find projectors using the 9007 bulb? All the ones I looked at use H1 bulbs. I wanted projectors after I got my hid's but didn't want to buy two H1 bulbs too.
  7. #7 Re: about to order HID's...
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by corsagtp View Post
    I'm using a 9007 relay harness with the projectors. The projectors use an H1 bulb. I was able to keep the 9007 relay harness.
  8. #8 Re: about to order HID's...
    Norristown, PA
    boost let me know how this goes, i want to do hids too but i want to see how hard it is to install
  9. #9 Re: about to order HID's...
    Quote Originally Posted by rocafella2032 View Post
    About as difficult as installing an electric fan on an old car.
  10. #10 Re: about to order HID's...
    Norristown, PA
    are they plug and play? thats about all i can handle
  11. #11 Re: about to order HID's...
    Joliet, IL
    im judt gonna get lowbeam hid H1 kit i dont think ill need brights i already never use them with silverstars...and roca ill let you know i think im gonna order from diode dynamics?
    00 Silvermist GTP
  12. #12 Re: about to order HID's...
    Aug 2008
    KCMO
    i have s et from them and i love them it make s a world of difference and im sure it gunna be even better with your projectors
  13. #13 Re: about to order HID's...
    Dec 2008
    Lawndale, CA
    HIDs will not melt the projectors. I have been using HIDs in them since I got them from the group buy awhile ago.
  14. #14 Re: about to order HID's...
    Norristown, PA
    ok..sounds good bro. keep me posted!
  15. #15 Re: about to order HID's...
    http://www.grandprixforums.net/f11/u...read-2415.html
    I'm skimming it now to see if I can find anything useful. Might want to do the same.
  16. #16 Re: about to order HID's...
    Banned - Busted For Scamming
    Feb 2009
    Its about 3x the light output. Figure about 1000 lumens for the 55w halogen and around 3000 lumens for the hid depending on the color temp you get.
  17. #17 Re: about to order HID's...
    GT Level Member GrandPrixGT00's Avatar
    New Jersey
    can they melt stock housings?
  18. #18 Re: about to order HID's...
    Topeka, KS
    I haven't heard of anyone's melting yet but i could be wrong.
  19. #19 Re: about to order HID's...
    Nov 2009
    Grand haven
    I got the 8000k head light and fogs plug and play for 90.00 shipped. I will never have std light bulbs again I have the hids on all three of my cars now..
  20. #20 Re: about to order HID's...
    Ever touched a headlight after running HID's for a while? They're cold... Halogens are the ones that will melt the housing.
    How do you think a 35W bulb can be much brighter than a 55 W without increasing efficiency?
  1. Looking to do HID's and need some input
    By J06GT in forum Audio, Security & Visual Electronics
    Last Post: 11-23-2009, 06:27 PM
  2. HID's installed!!!!!
    By tmackster in forum Visual/Body Modifications
    Last Post: 10-23-2009, 09:57 PM
  3. My new HID's and subs
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 06-27-2009, 09:55 PM
  4. HiD's again lol
    By gptrell502 in forum Visual/Body Modifications
    Last Post: 04-10-2009, 02:25 PM
  5. HID'S - Who, What, When, Huh?
    By Billyb in forum General Tech Discussion
    Last Post: 03-26-2009, 04:58 PM
