Thread: Fuel leak
Results 1 to 10 of 10
  1. #1 Fuel leak
    Feb 2010
    West Carrollton OH
    Someone tell me there is a reason, besides a hole in the tank, that would cause fuel to leak down the passenger's side rear corner of the fuel tank. Right on top of the exhaust no less. i just noticed it after i filled up. i checked the fuel pump door in the trunk, no seals leaking or anything. just bought the car a couple weeks ago. If i had the tools to drop the tank this would be a much easier matter! Thanks in advance for the help. its a 1998 GTP. it starts and runs fine
  2. #2 Re: Fuel leak
    GTX Level Member cerick08GP's Avatar
    Never heard this one before. It actually sounds like a dangerous condition. I’d have to go with a faulty repair job in the past, or a plain old age related issue. It is definitely not a common problem by any means, if that is what you were asking. Good luck.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  3. #3 Re: Fuel leak
    Feb 2010
    West Carrollton OH
    thanks for the reply, i was just hoping there is some stray fitting or fuel line on that side of the tank i'm missing, yeah imagine my surprise when i hear something that sounds like bacon going to a hot pan under my car, and look to see its fuel cooking off a hot exhaust
  4. #4 Re: Fuel leak
    Charles City, IA
    Fuel line probably cracked. I would fix it asap.
    SMGPFC Two Nipple General
  5. #5 Re: Fuel leak
    Feb 2010
    West Carrollton OH
    that would be awesome except there are no starting problems and the car runs great. the fuel lines all run down the opposite side(or at least from what i can see) i replaced the fuel filter a couple weeks ago so i rechecked that and it and the fuel lines around it are all dry
  6. #6 Re: Fuel leak
    Charles City, IA
    Could have a hole in the top of your tank. hook up a smoke machine to it and see where the smoke comes out.
  7. #7 Re: Fuel leak
    Feb 2010
    West Carrollton OH
    i found it, it has a pinhole in the top of the tank. i got the tank out and i'm probably going to use some jb weld on it. i'm also going to do some sanding on it and spray the whole tank with underbody coating. any tips on putting it back in?(took me 6 hours to get the d**n thing out) or problems i don't see with painting it with underbody coating?
  8. #8 Re: Fuel leak
    Charles City, IA
    You will be fine under coating it.
  9. #9 Re: Fuel leak
    Feb 2010
    West Carrollton OH
    alright, thanks for the help
  10. #10 Re: Fuel leak
    Largo, Florida, United States
    JB weld saves the day!
  1. fuel leak issue
    By GTX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-07-2011, 07:14 PM
  2. Fuel Leak Question???
    By BDEGhost in forum General Tech Discussion
    Last Post: 11-11-2009, 11:53 AM
  3. fuel leak, trans not shifting
    By LogicGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 10:06 PM
  4. diagnosing fuel leak
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2008, 03:27 AM
  5. fuel leak
    Last Post: 08-18-2008, 03:40 PM
