Thread: car surges at 1500 rpm at 55 mph
Results 1 to 7 of 7
Mean Green 99 GTP car surges at 1500 rpm at 55... 03-05-2010, 10:29 AM
CTKGP09 Re: car surges at 1500 rpm at... 03-05-2010, 10:47 AM
Mean Green 99 GTP Re: car surges at 1500 rpm at... 03-05-2010, 11:02 AM
blowfishRus6 Re: car surges at 1500 rpm at... 03-05-2010, 11:53 AM
Jakegday Re: car surges at 1500 rpm at... 03-05-2010, 03:32 PM
Mean Green 99 GTP Re: car surges at 1500 rpm at... 03-06-2010, 10:59 AM
Mean Green 99 GTP Re: car surges at 1500 rpm at... 03-06-2010, 11:01 AM
  1. #1 car surges at 1500 rpm at 55 mph
    iowa
    i have 2 things going on at 55 mph at about 1500 rpm the car will surge and the trac light is off when i turn the car on also the car has to crank a while before it starts not very long about 4or5 seconds
  2. #2 Re: car surges at 1500 rpm at 55 mph
    Willoughby, Ohio
    welcome to the foums. probably a sensor like usual. does it still surge with trac off?
  3. #3 Re: car surges at 1500 rpm at 55 mph
    iowa
    the trac control is off when i start the car and it should be on
  4. #4 Re: car surges at 1500 rpm at 55 mph
    Donating Users blowfishRus6's Avatar
    g.a.
    do the rpms bounce around?? if so it could be the torque converter lock up sliping.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  5. #5 Re: car surges at 1500 rpm at 55 mph
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    does your tach drop to 0 during any of this?
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  6. #6 Re: car surges at 1500 rpm at 55 mph
    iowa
    the tach does not drop to o
  7. #7 Re: car surges at 1500 rpm at 55 mph
    iowa
    also my trac light does not come on when i turn on the car the track light is off might have something to do with it.
  1. Engine surges and cuts out
    By timmyg in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-02-2010, 04:26 PM
  2. 1500 rpm cut out or misfire
    By Planeboy18 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-22-2009, 01:38 PM
  3. 1500 Members strong!!!
    By UR LOSN in forum Off Topic Discussion
    Last Post: 07-12-2008, 09:09 PM
  4. Car runs rich and surges at an idle?
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2008, 02:54 PM
